Question about Danby DCR34 Compact Refrigerator
I have a danby dcr34 mini fridge that keeps clicking but won't get cold
3 Suggested Answers
  • 317 Answers
SOURCE: I have a very old
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Posted on Jul 14, 2011
oldTech2332
  • 2341 Answers
SOURCE: is 6 or 1 the
1 is the warmest setting
6 is the coldest
Posted on Sep 04, 2011
It's a Danby and brand new i won it why and how do I fix problem of fridge not getting cold ?
dambys a usually very good
humm
not getting cold even when dialled to coolest
how long has the unit been on
can you hear the motor /compressor
kicking in and out or running at all
which model and size is this danby then
i can get a look at its user manual
http://kitchen.manualsonline.com/manuals/mfg/danby_products/danby_products_refrigerator_product_list.html
May 19, 2016 | Danby Refrigerators
Fridge will come on and run for 30 seconds then shut off. repeats this steady. i think it is a thermostat problem.j
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 19, 2011 | Danby DCR34 Compact Refrigerator
I have a ignis fridge 2 door, when the electricity goes off, water from the fridge runs down to the floor. is it normal for it to behave like that when the power is off? i dont have a manual
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Danby DCR34 Compact Refrigerator
On my danby refrigeator by turing the temp gauge from high to low is low the coldest
NO.low is the warmwest,i use a thermometer to run my fridge at +3C to+5C.that way you dont get black lettuce.......
Feb 27, 2011 | Danby DCR34 Compact Refrigerator
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
Camper fridge
if it is a 3 way fridge pull it out and turn it upside down and leave for an hour or so and then turn back for an hour or so and continue this for half a dozen times the gas inside the pipes have seperated and require mixing up particually if it is fairly old or has been sitting for a long period as u discribed
Jul 28, 2009 | Danby DCR34 Compact Refrigerator
Brand new danby dcr34bl refrigerator not working
Often times refrigerators need to sit for a day or so before being used, moving them scatters the refrigerant through the system making them useless.
It is also possible that durring shipping the system may have been compromised, allowing the refrigerant to escape. Have a technician check it out before you try to return it
Jun 04, 2009 | Danby DCR34 Compact Refrigerator
Pressed a button, now fridge won't work
you have pressed the defrost button that is why the compressor stops and would not come back on. there could be a temperature sensor on the thermostat or a timer where in it would only reset back after the temperature of the fridge warms up. try to remove all the food and let is sit for a while, plugged and watch if the compressor would kick in after about two hours or untill the fridge warms up. if the button is stuck, you may have to spray lubricant in the thermostat or replace the thermostat .
Feb 21, 2008 | Danby DCR34 Compact Refrigerator
After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
Aug 10, 2007 | Danby DCR34 Compact Refrigerator
Danby DCR34 Compact Refrigerator Logo
91 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
