Question about Garden
Cuts for an hour then engine begins to sputter
Twin cylinder kohler engine
    Sergeant:
  • 322 Answers
Sounds like an ignition module is going out.
Posted on Jan 17, 2013
Fuels ok 16 hp kohler on Scott mower cuts grass for about an hour then sputters and won't run under a load let cool down for about 20 min and it's fine
you need a valve job done on it valves are not seating causing lost power and is superheating engine take in to shop 100.00 per cylinder
Sep 13, 2014 | Garden
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
now the kohler v-twin does have a bit of a problem with camshafts in this size range , your gonna need to remove valve cover on head side that you suspect is bad , verify that valves move in order (one at a time) as you turn over by hand with spark plugs removed (both sides)
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Runs good for an hour then engine begins to sputter
Once it starts sputtering carefully pull a spark plug wire off (it can shock you) and see what happens. It sounds to me like you have an ignition module issue that once it gets hot it is grounding out and then when it is sputtering it is because you are running on one cylinder
Jan 02, 2013 | Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Kohler courage 23hp twin cylinder ohv on a troy-bilt 50 '' horse. Run great for awhile then start to lose power and cut off.After cooling the same problem starts again.
Hmmm... first off, check the oil and make sure it's at the proper level - low oil can cause overheating. Second, if you haven't cleaned the engine and it's full of yard dirt and dust then you need to blow it out with about 100psi of air. Blow down through the cooling fan on top of the engine and make sure all the fins around the cylinders are clean of debris. Sound like the engine is cooking..
Aug 09, 2011 | Garden
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Feb 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Can you give me a ballpark figure on replacing a head gasket on a older Craftsman riding lawn mower...
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
