Question about DeLonghi Esclusivo Gran Dama EASM6600 Stainless Steel Espresso Machine
Need part number 5213214851
Display out and looking for part 5213214851
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
Delonghi gran dama display light out
This is a common problem fixed by replacing the control board. The part number is 5213214851 and costs around $135. It is a rather easy fix for someone who can take things apart and put them back together using basic tools.
Or, sending it to a reputable shop will cost about $40 for shipping each way, plus around 1.5 hours of labor, and maybe a small markup on ordering the part for you.
Apr 06, 2012 | DeLonghi Esclusivo Gran Dama EASM6600...
Bernina b350 display
You need to go into the setup menu and find the display contrast setting - you should then be able to adjust the contrast to get a better display - look at your manual for this.
Mar 03, 2012 | Sewing Machines
The LCD display is not showing the numbers correctly. It looks like the numbers are missing "lines", like an 8 can look like a 3, the 8 can look like a 0, etc. Any ideas?
It is the control board that needs to be replaced. The LCD display is connected to the board. If this is an above the stove microwave the problem was caused by the steam from boiling water on the stove top. you can prevent it from happening again by using the vent fan consistantly.
Dec 01, 2010 | Sharp R-1511 Microwave Oven
Need a code to unlock my radio for a 97 grand prix
Follow these steps to unlock your GM Delco Radio:
1. Turn the ignition ON (The Delco radio displays "LOC" or "INOP").
A. If your radio says "INOP" then you have entered too many wrong codes. You will need to run the vehicle for one hour or turn the key into the ON position for one hour before you can proceed to Step 2.
2. Looking at the face of your GM Delco radio, hold down the preset buttons 1&4 or 2&3 for approximately 10 seconds. The radio display changes from "LOC" to a three-digit number. Write this number down.
3. Press the AM/FM button. The radio display changes to another three-digit number. Write this number to the right of the first one.
4. You now have a six-digit number, the first three digits are from STEP 2 and the last three digits are from STEP 3, you will have a number like this (612-622).
A. NOTE: Saturn and GEO vehicles will only display a four-digit number. The fourth digit will be displayed half the size of the first three digits. Example: 2193.
Hope helps (remember rated and comment this).
Sep 02, 2010 | Pontiac Grand Prix Cars & Trucks
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
My display numbers are upside down.
If this unit has worked before, and suddenly looks upside down, you are most likely seeing a display with missing or defective sigments. There are 7 segments needed to make number from 0 to 9. When a segment goes bad, you will see something different.
Sometimes the internal connections to the LCD display are dirty or corroded.
Oct 18, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
JenAir SVD48600W clock display is out.
They were known for bad display boards. Changing the display should solve it. Take the model number to and appliance store and have them look it up and order it.
Sep 01, 2009 | Kitchen Ranges
DeLonghi Esclusivo Gran Dama EASM6600 Stainless Steel Espresso Machine Logo
64 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
