Question about eMachines eM250-1915 Netbook
Emachines netbook will not power up properly after fitting a new screen
Just fitted replacement screen,fan starts on boot but stops 10 seconds or so after boot,checked connections ie screen ,hard drive, memory chips,screen model is same
    New Friend:
  • 51 Answers
Try changing different ram memory...tekgods.com
Posted on Oct 26, 2013
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: need to remove the screen from my emachines 5405 laptop
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these, they are under the plastic panel next to the hinges.
Posted on Feb 01, 2009
  • 302 Answers
SOURCE: This netbook will not start. Power is plugged in
reseat the memory cards if they are loose there will be no video showing on screen.
Posted on Jun 19, 2010
Emachines 250-1162 will not boot at all
I would say the battery has gone bye-bye. Some laptops won't even boot without a good battery.
Oct 03, 2014 | Computers & Internet
My notebook will not boot properly, and date and time resets.
please use this small secret. Disconnect the power adapter from computer 2) DISconnect the battery from laptop.
3) Press the main button power for 60 seconds exactly. This method discharge any ESD. keeping in the system. and try again, will be work.
However if the problem persist see the flow charts. attached.
Mar 06, 2013 | Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
The slightest of jolts and it crashes why a new fan has been fitted some 8 weeks ago appx and it started to crash just after that ??
Verify that the person who replaced the fan correctly removed the old heatsink (thermal) compound and replaced it with new compound. Verify that the fan is connectect to power - you should hear it spin up intermittently during use, especially if you stop the Thinkpad in the Setup program when turning it on. (Pressing F2 or ENTER usually takes you into the setup program - press the key indicated on the Thinkpad screen on initial power on). The fan should be audible within 10 to 20 seconds roughly. If you don't hear the fan power-off the Thinkpad and check those two things.
Caution: Excessive heat can permanently damage the notebook computer! Don't let it run for more than 60 seconds in SETUP without a working fan because the CPU will run at 100% load while in SETUP. (It's normal behaviour though because CPU Idling isn't implemented in the SETUP program)
Apr 14, 2011 | IBM ThinkPad T41 Notebook
My Acer Aspire 5920 does not start up after pressing the power button, nothing on the screen at all. However the lights are flashing. Before this problem, the screen froze when I was using it. What's the...
Possibly a RAM issue or errors on the hard drive stopping the display driver from working properly. Remove power sources, remove RAM and hard drive. See if you get a display when the power adapter is reconnected. If you do, remove power source and fit RAM, (if not motherboard may be faulty). Repeat and if still working, remove power, fit Hard Drive and boot again.
Assuming your OS is Windows Based;
Reboot and use safe mode run CHKDSK/F and when finished check the drivers.
Feb 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
My N450 Emachines netbook's monitor is too large to fit on the screen, how to adjust? pls reply
at desktop right click, then click personalyse, click dispaly setting, than adjust display setting
Jan 24, 2011 | Acer eMachines 350-2074 Netbook
My emachine netbook will not starts up at all.. i tryed the alt F10 but it freezes.. likw the big E shoes then after that its a blank screen
If the initial display is coming and machine is not booting into OS then the issue is linked with OS and you need to recover it.
If there is black screen at all please refix the battery once and check. If this does not work please check whether power is there in the machin eor not? If power is there issue is with mainboard or RAM.
Refix the RAM once (will be in chamber in bottom of the notebook). If the issue is not resolved then you may have to call service center.
Thanks
Jan 04, 2011 | Acer eMachines eM2501162 Netbook
How to fix emachines netbook , model 250-1162 the 10.1 LED LCD screen will not turn on
Is it the screen or the laptop?
Have you plugged an external monitor to see if its booting?
If it is booting with an external monitor, you may need a replacement screen (google your model and replacement screen)
If its not booting, you could try this.....
http://www.fixya.com/support/r5335055-unable_start_windows
Jul 18, 2010 | Acer eMachines eM2501162 Netbook
eMachines eM250-1915 Netbook Logo
83 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
