Question about GE JKP15 Electric Single Oven
Need manual for ge p7 wall oven jkp16
I need to buy a new wall oven. i need to know the dimension of what i have to know what size oven to buy and if the cabinet needs to be modified.
SOURCE: GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
Posted on Dec 20, 2007
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: GE P7 Oven 2 burners out on stove top
Purchased a new stove.
  • 65 Answers
SOURCE: GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Posted on Jan 28, 2009
SOURCE: GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Posted on Aug 05, 2009
Testimonial: "thanks!"
How do I replace the temperature controller in GE model P7 oven?
should be easy make sure u unplug from wall then in the back panel u can unplug after making sure to note where wire plugs are connected and ifinite switch can usually be removed by removing the screws holding it. remember to remove the knob from other side
Mar 08, 2015 | GE Ovens
How can I check thermostste on GE P7 before buying new one
wow much to high to pay? it can be checked for continuity with an ohm meter. u can buy cheap meters for like 5 bucks or so. are u sure their trying to charge them much for a thermostat? maybe they thought u meant something else? if its getting way to hot u have a bad oven sensor? it to can be checked with a meter. When ur thermostat goes out due to overheating , the oven will not operate. thermal thermostats are not resettable. oven sensor is located near the back along the wall it thin and may have a glass look?
Feb 12, 2015 | GE Ovens
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: http://www.geappliances.com/ge/service-and-support/literature.htm . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675840.PDF . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
Where can I buy an oven rack online?
You will first need to know what dimensions you need. I located a great site that sells a variety of sizes of racks - hopefully this helps http://www.kitchenstuff.com/items.asp?Cc=SP1010.
Jul 12, 2012 | Electrolux Double Wall Oven Rack 19 3/4" X...
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
What year was the ge p7 wall oven manufactured? trying to find out the age of the oven.
I can go back to 1974-5 for mine, that's when my original Landlord bought the place and it still has the same GE P7 as when the complex was new...and it still works.
Oct 30, 2009 | GE Ovens
Jul 15, 2009 | GE JKP50SH Electric Double Oven
Jan 28, 2009 | GE JKP50SH Electric Double Oven
GE JKP15 Electric Single Oven Logo
35 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
