Question about Mitsubishi WS-65712 65" Rear Projection Television
CONVERGENCE WILL NOT PROPERLY CONVERGED
TV DEALER SAYS CHIP IS BAD AND NEEDS TO BE REPLACED AT A COST OF $500 PLUS LABOR?
  • Mitsubishi Master
  • 8,617 Answers
You only need one STK393-110 Convergence IC and two 5Amp pico fuses. You can get the IC and the two fuses for less than 35.00 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 19, 2009
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
AV-48WP30 - Is this a convergence board issue?
yes u r right that is the problem of convergence in your televisions.and it needs to be replaced to make it proper.
thanks.
Oct 29, 2008 | JVC AV-48WP30 48" Rear Projection...
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
There is a blue color shift to the right making people look like they have a blue shadow. Thanks. Matt.
it is a convergence failure
you need new stk chips to fix
this is complicated and requires soldering
typical cost 150 to 300
if you are crafty i can give you ideas on how to improve the picture without repairing but you will have to reach near high voltage lines, let me know if you feel so inclined
May 21, 2010 | Televison & Video
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Mitsu Proj TV WS-65711 needs Converg IC chip. Part Co$t + labor?
There is either a pair of STK392-570's, or
a STK393-110. Probly also 1 or 2 pico fuses for the +/- 26v line in the power supply.
Parts aprox 80.00 to 90.00
Labor 150.00 to 180.00
Plus service call fee if any.
So figure it up from there. Labor cost does vary from location to location. I do feel confident that capasitors are not causing this problem in the way you explained the symptoms.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WS-65711 65" Rear Projection...
I have a Hitachi 53uwx10ba has double colors red and bleu
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 24, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence chip
Convergence ICs cost around 15-25 each there are only two of them. I would go ahead and replace both of them because if one goes the other one will follow shortly. I would make sure that it is just the convergence IC not something else, and if its over five years old dont pay more than $500.
Nov 04, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Power supply/convergence issue...
Your Projo is a complicated piece of equipment, involving 3 picture tubes (like 3 tv's), convergence failures are extremely common, I dont think $550 is totally unreasonable, but I dont think it is a power supply issue if it is just effecting 1 color, usually it would cost around $100 parts $300 labor to repair, might be a little high, I suppose they are also charging you for pickup and delivery, I hate taking sets into office as that sometimes jars stuff loose or cracks boards.
Jul 10, 2007 | Panasonic PT-47WX51 47" Rear Projection...
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
Mitsubishi WS-65712 65" Rear Projection Television Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
