Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
Acomodata Hybridrive ext HD 2.0; software won't download
My windows XP pro (200 versions) says computer will not allow download of HD drivers- as it's already built in the system? Weird. Can't get any set up; no icons, nothing. simply won't install. Any help? \
Thanks!
I. have this problem:
setup will not install any drivers on this operating system since the operating system has in- built support for this usb devise
Tank´s. A.L.
Posted on Feb 11, 2009
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
I wish that I had better news for you.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
Dc 7600 is no saund
You have SP3 and HD audio give this a try:
This patch is required before any of the HD device drivers are installed
1. On your PC change the CSDVersion registry key to XP SP2:
HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=200
2. Restart your PC
3. Install KB888111xpsp2.exeHD_Audio/kb888111xpsp2.exe and your audio driver.
4. Change the CSDVersion key back to XP SP3 again:
HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=300
5. Restart your PC, finalize configuration of your PC, sysprep and capture.
Simplified Directions
Goto Start>Run and type in regedit , then click OK.
Click the plus signs in front of HKEY_LOCAL_MACHINE, SYSTEM, Current Control Set, Control, and finally, click Windows.
In the right panel you will see CSDVersion.
Right click it, choose Modify.
In the highlighted input window, you should see 300. Change it to 200.
Click OK, close regedit and restart your PC. Windows will now think it is SP2 and allow you to install the UAA and your HD audio driver.
Make sure to reboot and then test your sound BEFORE, changing the value back to 300.
Then follow the same steps to change it back to SP3. Change the 200 back to 300.
Jul 22, 2011 | HP Compaq dc7600 Convertible Minitower PC...
I havent got any sound drivers and want to download them for free
1) Go to the toshiba support site for these notebooks:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2041070&rpn=PSLB1U&modelFilter=L300-EZ1004V&selCategory=2756709&selFamily=1073768667
2) On page 3 of the downloads, second link from the top is a sound driver. Click on the link.
3) A frame will pop up with a link to "Download Now"
4) Download the installer to your computer and follow the directions.
Enjoy!
May 07, 2011 | Toshiba Satellite Pro L300 Notebook
I hav downloaded intel dg31pr audio driver for windows xp but while installing it appeard as "this driver version is older than the system one". please solve my problem...,,,
Well mahatab9, you have not told us if there is any audio driver installed on your computer or not. But the error message clearly stated that, you have an audio driver already installed for your motherboard model. So, if the driver is not properly working or you just want to upgrade it, you should use Intel Auto Driver Updater for best result. This will show if there is any updated version of your installed drivers are available or not. To do this, click on the following link to automatically identify and update your drivers and softwares.
Automatically Update your Driver
Now click on "Check Your System for Latest Updates" to start analyzing your computer. This will show whether your system requires an upgrade or not.
IMPORTANT: This utility is for Intel Motherboards only.
But still, if this utility doesn't show any upgrade to your audio driver, then you can manually download this driver as your motherboard INTEL DG31PR supports the Realtek HD Audio driver only for best response. If you have already installed any other audio driver than Realtek, please uninstall that and install this one. To download this, click on this following link:
Download latest Realtek HD Audio Driver
This installation will remove any previous version of Realtek and install the newest one automatically.
Hope this helps, Regards,
Mrityunjay
May 06, 2011 | Computers & Internet
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
How to install XP in toshiba Satellite L45-S7423 laptop
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
Aug 14, 2008 | Computers & Internet
HP Pavilion DV1000 drivers...
I found the problem to be a rather simple but frustrating one....when is an HP dv1000 not a dv1000....almost always!! You cannot get the correct downloads based on the model number on the tag. You must specify the PRODUCT NUMBER on the HP download site from the tag, not model. You can enter the general DV1000 and get to the download page and look for the entry "Not your Product?!" Follow that link and enter the PN from the tag....download those and you will get drivers that work with your unit. My "DV1000" was actually a DV1660!!!!
Jul 26, 2008 | HP Pavilion dv1000 Notebook
Xp audio driver for fujitsu amilo
Downloads results for AMILO La 1703 CLICK HERE FOR AUDIO DRIVER
CLICK HERE FOR SUPPORT PAGE AND ALL THE DRIVERS
VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed)
Title: VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed) Date: 04.10.2006 Size: 7,17 MB Version: 5.10.01.1080 Manufacturer: VIA Technologies Status: Released for AMILO La 1703 Language: all.gif Supports all languages Operating systems: [Supported] Windows XP
[UnSupported] Windows XP Media Center Edition (WHQL)
Minimize up.gif Use in the following products: minus.jpg AMILO La 1703
Jul 03, 2008 | Computers & Internet
Hello. Simply need XP drivers for e-machine model W4682 so XP can be reloaded from scratch. Vendor site is useless. Any info would be helpful.
here you go this should be all your drivers.
Modem Description Riesling Modem Driver File Type Original Driver Version 7.4.5.50 Operating System Windows XP Driver File Download (1.44 MB)
Chipset Description Intel Chipset Driver File Type Original Driver Version 5.0.2.1003 Operating System Windows XP Driver File Download (2.65 MB)
Video Description Intel 845GV Video Driver File Type Original Driver Version 6.14.10.3722 Operating System Windows XP Driver File Download (7.15 MB)
Media Reader Description Universal 8-in-2 Media Reader Software File Type Original Driver Version 1.08 Operating System Windows XP Driver File Download (4.40 MB)
Audio Description Realtek AC'97 Audio Driver File Type Original Driver Version 5.10.0.5320 Operating System Windows XP Driver File Download (16.70 MB)
Network Description RealTek Onboard LAN Driver File Type Original Driver Version 5.606.811.2003 Operating System Windows XP Read Me File Download Driver File Download (2.20 MB)
hope this helps if this isnt the correct series its the w-468 series drivers
Jun 18, 2008 | E-Machines Computers & Internet
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
327 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
