My Samsung screen flickers on powering on until it stops after a few minutes. what can I do? Thank you all.
    Sergeant:
  • 475 Answers
Unplug it and let it sit for a half hour and plug it back in, or call the company themselfs with the 1-800 # they give you.
Posted on Jan 02, 2013
3 Suggested Answers
  • 1684 Answers
SOURCE: Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
budmrtn
  • 11361 Answers
SOURCE: the whole screen flickers. Some time turning it
Does it do the same if attached to another PC?
It may have dying power supply due to bad caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 05, 2011
What does is mean when black flickering lines from top to bottom of screen appear when i first turn my samsung 50' model un50f5500 HD plasma tv on but goes away after a few minutes
It sounds like either your main board or logic board is going out.
You might want to check the capacitors on your power supply also. If they are swollen they will need to be replaced. Swollen caps can cause video distortion until they build up a good charge. Good luck to you.
Apr 12, 2016 | Samsung Televison & Video
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Flickering screen
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Jul 15, 2010 | Samsung SyncMaster 205BW LCD Monitor
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung DLP 42" flickering green screen
Just unplug and plug back in. Worked for me.
Try it a few times.
May not work for everyone.
Apr 21, 2008 | Samsung HL-R4667W Rear Projection...
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Picture Flickers Briefly Shortly After Power on
If the set is only a few weeks old you should put a claim for a warranty repair or exchange I believe is the back light(lamp)doing the flickering and should not be doing that at all and it will not go away by itself,it might get worst. Let Us know how it goes or if you need more information.
Nov 03, 2006 | Hyundai Q320 32 in. LCD Television
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
