Question about Asus Systems Asus Cm6870us3aa Desktop Core I73770 3
I have a Maximus V Gene motherboard and the I73770 CPU and keep getting a CPU error on the board and the CPU fan continues to go on and off. What is the problem? Both are brand new.
We replaced the CPU with the same model last night and same problem continues.
    Problem Solver:
  • 9 Answers
Make sure you`re motherboard supports you`re cpu,Heres a list for compatability http://www.asus.com/ROG_ROG/MAXIMUS_V_GENE/#support
Also is your powersupply suffiecent enough(IF you have a powerful Graphics card)
Make sure the cpu power cable is plugged in .usually a 4 or 8 pin
Posted on Oct 23, 2013
I have a gateway notebook model #mt6451 i turned it off last night and i turned it back on this morning and the screen wasnt coming on the power button lite up cd made noise fan working and hard drive...
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptop into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, simply shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptops.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Mar 19, 2014 | Computers & Internet
Which motherboard is suitable in replacement of p5kpl-am/ps motherboard?
if you mean upgrade take a 1150 motherboard like z87 - plus or maximus VI if you mean replacing but keeping cpu then any p5kpl will do like ipc or -se -vm etc.
Aug 17, 2013 | ASUS P5KPL-AM/PS Motherboard
Sputtering while driving
Have the fault codes read. Replace faulty items. Use only genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units I would have the fuel pressure in the manifold tested as well .The engine light is telling you that the CPU has found sensor/s outside set
parameters during the checking process
May 26, 2013 | 1998 Chevrolet Cavalier
Asus maximus iv gene z error code 45
A Windows Error code 45 will display or populate a error message that looks similar to the following:
Currently, this hardware device is not connected to the computer. (Code 45)
The device is not present or was previously attached to the computer. If Device Manager is started with the environment variable DEVMGR_SHOW_NONPRESENT_DEVICES set to 1 (which means show these devices), any previously attached (NONPRESENT) devices are displayed in the device list and assigned this error code.
What is the solution for this then?
To fix this problem, reconnect this hardware device to the computer.
No other resolution is necessary.
Visit also asus, and look for any driver updates for the mainboard:
http://www.service.asus.com/#!downloads/c1wax
Good luck
Jan 24, 2013 | Computers & Internet
Asus p6t se
harry up change cpu fan or" pemanent damage your cpu if fan is off.
May 30, 2012 | ASUS P6T SE - Motherboard - ATX - iX58 -...
Maximus motherboard with intel x38 chipset won't boot
There's a chance of overclocking, ram failure, bios failure, cpu overheat, power supply problem,etc.. But in the first step, remove everything which are inserted on the board, like power cables, processor, rams, bios battery, Pci cards, sound cards, etc.. and clean them using soft brush, also clean the mother board, there might be dust clogging the chipsets like resistors, transistors and capacitors, and reinsert everything after cleaning... I hope this will help if there's only a small problem except circuit short... Good luck...
May 06, 2010 | ASUS Maximus Formula Motherboard - 45nm...
Asus Systems Asus Cm6870us3aa Desktop Core I73770 3 Logo
69 people viewed this question
Top Asus Systems Computers & Internet Experts
Terry Schallert
JonSnell Electronic
JonSnell Electronic
gaucherre
Are you an Asus Systems Computer and Internet Expert? Answer questions, earn points and help others
