I purchased a mantel fireplace from Fingerhut last March. The name on fireplace is FEBO FLAME. Now the on switch lites on but theres no flame or heat. The buttons on fireplace or remote do nothing. Id like to find out if there is a fuse causing this problem. Or what else it could be. Im getting nowhere with Fingerhut and Im very upset that I paid 500.00 for this item. Id appreciated any feedback you could give me. Thank you.
    Problem Solver:
  • 8 Answers
Since it can be a potential hazard, it must have safety protocols in place. If you have the owners manual, Read it's instructions carefully. Look through manual for TROUBLESHOOTING then look for safety locations, there you should find all the answers to your questions. Good Luck too you.
Posted on Jul 05, 2017
WebTeligent
  • 42 Answers
SOURCE: failure to establish flame
I the electrical gas switch valve set to on? If not...
Is there also a gas valve and is it on? If so...
Does the exhaust fan turn freely?
If not then then electrical gas valve will not open the gas valve. I have seen these bearing get loose and then the exhaust tips toward the inside inhibiting the fan from turning. Note: this is not the large blower but a smaller fan for the exhaust fumes.
Is the Vacuum hose from the exhaust to the sensor in good condition and attached at both ends? If not fix hose or connect both ends.
When repairing a unit, many tech will turn off the gas for saftey.
Posted on Nov 10, 2007
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heat n glow fireplace comes on fine with all
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Posted on Nov 05, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
Flames wont move
There should be a small electric motor that turns the wheel that looks like flames. That little motor may not be working making it look like the flames don't work. May have to replace the motor.
Dec 03, 2014 | Classic Flame Nantucket Corner or Flat...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
Instructions to put a febo flame fireplace together
my fireplace is missing the instructions
Oct 28, 2010 | Heating & Cooling
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
