Question about HP PhotoSmart Office Equipment & Supplies
Error code Oxc 19a 0007
Whenever I attempt to print something I get this error code. I took out the print cartiages, unplugged the power cord, and nothing seems to work to correct this problem.
2 Suggested Answers
  • 1382 Answers
SOURCE: error code Oxc 18a 0007 appears and can not print
The "Ox18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Posted on May 19, 2010
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
The Ink waste tank filters are usually change by a technician or the counter can be turned back. The ink waste tank is found at the base of the printer
Aug 08, 2008 | HP Photosmart 3210 Printer
My HP Photosmart C5180 all in one is displaying this error Ink system has failed refer to printer documentation OXC 19a 0035 cannot find out what it means?
The "Ink System Failure" is caused by air in the ink feed tubes. This problem can happen if you allow your ink to run all the way out or if you use poorly refilled ink cartridges that have air bubbles in them. To clear the error you will need to perform a purge on the printer. We have a step by step guide to this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get you back printing in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error code Oxc 18a 0007 appears and can not print
Thank you!!
May 19, 2010 | HP Photosmart 3210 Printer
Error:Oxc 1ab ooo1 337:libmicc 12-12tango.c
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | HP Photosmart 2575 All-In-One InkJet...
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Hp c7180 ink failure
Here is the exact sequence for the C7180. It worked great for me:
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Jun 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
OXC : stoped printing
OXC? what would that mean, by chance? Is that an error code?
Oct 25, 2007 | HP Photosmart C7180 All-In-One InkJet...
HP printer hp D7163 error:OXC 18a 0205
this is beacuse of 2 reasons
1)printer internal firmware corrupt
2)ink system failure
try this
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer
60 people viewed this question
Seeker5211
Seeker5211
