LIGHT BLINKING NON STOP
SERIAL #9015323 ( 52'' ) YEAR BUILT 1997
MODEL # KP-53835
  • 2 more comments
  • freddiebowli Jan 20, 2009
    sony projector TV 52'' model #KP-53835 SERIAL #9015323 BUILDATE 1997 . THE POWER LIGHT BLINKS CONTINOUSLY , I'VE HAD THE POWER OFF FOR A MONTH .I CAN HERE THE RELAY CLICK AN THE POWER LIGHT COMES ON AND BLINKS NO PAUSES .POSSIBLE TO FIX !OR IS IT WORTH KEEEPING?????????
    is the tv worth saving 952'' sony projector) if the power supply board is bad , AND CAN I PURCHASE THE BOARD
    THANK YOU THATS WHAT I THOUGHT!!!!!! THANK YOU FOR YOUR HELP THIS HAS BEEN A GREAT HELP
    Sergeant:
  • 221 Answers
Just get it repaired it will be the costly issue as its the board failure.but its worth fixing as whole board which is faulty will get replaced.so not to worry.
Posted on Jan 20, 2009
  • 8,197 Answers
Your main board went out. Sorry you need to buy new TV
    Scholar:
  • 87 Answers
I`m guessing this is a Sony projection set but can you recheck tha model number for me.That is not a good number you provided.
Posted on Jan 19, 2009
  • 1 more comment
  • Albert Vasquez
    Albert Vasquez Jan 19, 2009
    I fix older Sony sets like these all the time.Depending on the correct model number you can get a power supply repair kit for this unit.I will provide that information when I get the model number.
  • Albert Vasquez
    Acme Enterprises (800) 575-9833 - Website
    Will have your kit.It will consist of a Horzontal output transistor,2 FET transistors,and a resistor.
  • Albert Vasquez
    Albert Vasquez Jan 20, 2009
    This is a KP-53S35 1997 model thats an "S" not an "8".For a constant red blinking LED
    Repalce Flyback part #(8-598-994-20) and the Horzontal output transistor part # (2SD2578.)Both are available @ Acme Enterprises (800) 575-9833 - Website. With out any troubleshooting I cannot say for sure that this is your problem and there is a possibility that you may have power supply problems. I as a technician would charge about $250.00 to repair this unit in shop.Call around your area and share this info with them.See what it will cost for this repair.Any shop in buisness only makes money if they can fix the unit @ a price that you agree is fair.
    Scholar:
  • 62 Answers
Sony or what type of tv? Led light what color?
  • Samuel Spell
    Samuel Spell Jan 19, 2009
    Not to old of a tv. please give more info.
  • 10,594 Answers
I'm afraid, its too old model and its parts are no longer available.
Better option to buy new TV.
    Sergeant:
    Scholar:
  • 199 Answers
It can be the power supply board problem.needs to be checked and replaced as all the lights are blinking.
    Genius:
  • 1,269 Answers
Which light is blinking? All of them? You can try to unplug the power first for few hours.
SONY KP-61HS20 DOESN'T COME ON JUST BLINK 6 TIMES PAUSE AND 6 TIMES AGAIN
Sis blinks of standby light denotes No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. If you wish to get more details about blinking codes to Sony PTV, check this link.
Mar 03, 2013 | Sony KP-57HW40 57" Rear Projection...
Panasonic tcp42x1 non stop blinking no powerup
It sounds that the main digital board has the fault. Non stop blinks of standby LED indicates that there is no serial clock, serial data flow. In other words, Bus circuit is blocked. This bus is generated from the main system control IC on the main board. As you know, there is no repair to this main board. Only replacement can be done as card basis.
Jul 07, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Blinking light on the mitsubishi projection tv & not turning on
A non stop blinking light is indicatring a problem with the Boot sequence. I will need the model number of your set as some models have known issues with bad DM capacitors that cause that symptom.
Jun 15, 2011 | Mitsubishi Televison & Video
How to stop my interior lights from blinking on and off non stop
The switch for your interior lights is part of your door locks on that year fords. check the strikker where the door sets over the pin. you will see the switch plate if the plastic is worn off replace the switch if not try titening the switch. to do this you will have to take the door pannel off and probly remove the lock
May 13, 2011 | 1997 Ford Crown Victoria
Green "clean" light is blinking non-stop and machine won't start
try pressing the buttons "Heated Dry, Normal, Heated Dry, Normal". It worked on my Whirlpool like a charm.
Sep 12, 2010 | Kenmore 24 in. 16033 Built-in Dishwasher
Sony model # KP-43HT20. power light flashes 6 times.
hello o Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
shaun
Nov 08, 2009 | Sony KP-43HT20 43" Rear Projection...
Wont turn on
Yes that is an error light. If you give me a minute I will try and get you more info on your tv.
Thanks,
lee
Jun 21, 2008 | Sony KP-53S35 53" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
C-Dog
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
