Have no hot water and spoke to an engineer and said it was the Diverter Valve. Can you tell me where the Diverter Valve is please. Thanks
  • Washing Mach... Master
  • 17,129 Answers
Never mentioned the model/make, trace the water line which leads to a valve from where it is branched to the hot and cold line valves.
You must trace this out.
Posted on Jan 24, 2013
2 Suggested Answers
SOURCE: F & P - GWL10 - Diverter Valve issue
Sounds like you might have the drain hose too far down the stand pipe and it's siphoning, try bringing the drain hose up a little.
Posted on Jul 15, 2008
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
How do fix a/c on 2003 yukon it blow cold then hot than back to cold
A few possibilities:
Stuck or inoperable Air-flow Diverter:
There are tow types of air-flow diverters: Vacuum Actuated and Slide-Cable Actuated (some will have an electric solenoid that controls a vacuum actuated type). In either case the default position of the diverter is "cold air" or closed - blocking air flow over the heater core. Sounds like it may have a vacuum actuated control - when it looses vacuum it will let the air-flow diverter swing shut blocking off air blow through the heater core resulting in "cold air" Could be a bad control/slider, bad or loose hose, or bad actuator. If you remove the blower motor assembly you will be able to see the diverter and might be able to tell the issue is.
Stuck or inoperable heater valve:
This valve controls the flow of engine coolant to/through the heater core. It is normally closed - blocking flow. This can be vacuum operated or cable controlled just like the air-flow diverter. Simple to check - in the engine compartment, to the left of the engine locate the cooling (heating) lines that go into the fire wall - locate the valve and check its operation.
Another possibility is low coolant level in your engine/radiator which may be too low to allow flow of the coolant through the heating coil, although you would likely notice that the engine was over heating/running hot.
Sep 13, 2014 | Flex A Lite 2003 GMC Yukon XL - 6.0L V8 -...
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Aug 19, 2014 | Heating & Cooling
Hi i have a ferroli optimax 31c , hot water works but my heating dont ,it comes on the the heat temp raises to its highiest then cuts of saying A3 AND D2 can you help please
hi had same problem engineer came out and the diverter valve was cloged up sorted it and recomended a system flush plus install a magnet clean whitch picks up debri be 4 it gets 2 the boiler.
Sep 26, 2010 | Quasar HQ2051TH Air Conditioner
I need to power flash a vaillant boiler. can you please help. water goes hold and cold, sometime the heating stop but the water works and vice versa. i was told by an engineering that it needs power...
Hi
Although not a PC problem, i have had this same issue on my Vaillant Boiler, the problem you are describing is not a power flush problem, you need to clean out your exisiting diverter valve or purchase a new one
The diverter valve is repsonsible for either providing hot water or providing hot water to the central heating, when this valve gets stuck in between the symptoms you have described above occur
I would also not recommned that you do a power flush yourslef as you may end up damaging the boiler and its pump
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | KDS Valiant 6380iPTD-01 Notebook
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Combi worcester 240. Plenty of hot water when heating running bot only luke warm when heating off. The pin in diverter valve working fine and ive tested the switch and that is ok !! Anybody got any ideas....
what u need to do is let the flow and return pipes for the heating go cold they are normally the 22mm ones and if 1 gets warm when u run your hot tap then u need a new diverter valve. if they stay cold then u need to see if the boiler is igniting in hot water so turn off the heating and just run the hot tap to see if it ignites get back to me
Jan 31, 2009 | Combi Centre DX - Mango
Hot Water Stays On
if this is a combi boiler switch off the boiler and call an engineer it sounds like the diverter valve is stuck
Jan 02, 2009 | Heating & Cooling
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
