Question about Adobe Photoshop Elements 2.0 for PC
Adobe photoshop elements scratch disks are full
I just installed Photoshop elements 2 and when I try to open it it says my scratch disks are full. My whole computer was just reinstalled last week so I know there is plenty of space and memory. Please help
pankaj_dic
  • 1250 Answers
SOURCE: Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Posted on Oct 28, 2008
SOURCE: AutoCrop tool for adobe photoshop
you can use actions in photoshop
Posted on Apr 29, 2009
  • 122 Answers
SOURCE: how can i download adobe photoshop free
hi,
go to download.com
u wil get it
Posted on May 29, 2009
  • 1738 Answers
SOURCE: serial number for photoshop elements 7
Try calling the company and tell them you bought the program and the serial no. doesn't work. If that doesn't work do a your favorite search engine serial for photoshop elements 7. Warning, do this can cause harm to your computer, with adware, mailware.
Posted on Aug 09, 2009
SOURCE: Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Posted on Aug 19, 2009
Could not initialize photoshop because scratch disks are full
Check to see if your system has enough memory and hard drive space. Photoshop should tell you how much memory and space you need. If this is a problem, you'll need to free up space. Photoshop may need to be uninstalled and reinstalled.
The scratch disks are areas of memory that hold your edits. If you don't have enough memory, you'll need to install more.
Nov 03, 2011 | Adobe Photoshop 7.0 for PC
Hello: I have Adobe Photoshop Elements 6.0,Windows XP with Pentium 2.8Gz and 1.59RAM. I set off on a mission to organize family pics but Photoshop Elements is driving me crazy due to several...
whats Graffi\'s automatic program, it sound like this program is incompatible with adobe photoshop elements. what format wereyour original files before you opened them in phtotoshop elements?
Feb 02, 2011 | Adobe Photoshop Elements 6: Windows
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
What does attempt to access invalid address mean in Adobe Photosh
Please turn your antivirus software to gaming mode and problem will be sovled.
Nov 17, 2009 | Adobe Photoshop Elements 4.0 plus Premiere...
When attempting to start Adobe Photoshop Elements 2, I get this message " Could not complete your request because of missing or invalid personalization information." Using a PC running XP home service pack...
OK, loads of different fixes for this, have fun.
These errors are caused when a version of Photoshop CS is already on the computer, such as a beta copy, or if your registration information file does not get written properly or is damaged. If multiple copies of Photoshop are in the Applications folder, or if a beta or tryout version is installed in addition to the regular version, the system and Photoshop may confuse which files to use to verify personalization. This confusion can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder in alphabetical order. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it.
Do one or more of the following solutions:
Solution 1: Remove and then reinstall Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's splash screen upon opening Photoshop, you may have another version of Photoshop CS on the computer. Empty the trash, remove the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
To remove and then reinstall Photoshop:
1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location.
2. Delete all Adobe Photoshop CS folder(s) in the Applications folder.
3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash.
4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: Remove and then reinstall Photoshop in another location.
If you uninstall and reinstall and still get personalization errors, or if you cannot locate an installed copy, uninstall any copies you find, empty the trash, and then remove Photoshop, and then reinstall Photoshop in another location that is alphabetically in front of any other installation.
To remove Photoshop and install it in a new location:
1. Move any personal files from the Adobe Photoshop CS folders on the hard disk to another location.
2. Delete all Adobe Photoshop CS folders in the Applications folder.
4. Create a subfolder in the Applications folder, that is named differently from the default Photoshop install folder (Adobe Photoshop CS), and is is alphabetically in front of the other version of Photoshop, such as \Applications\aaaa\Adobe Photoshop CS.
5. Reinstall Photoshop CS and select the new subfolder (created in Step 4) as the install folder when prompted for the installation location.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file:
1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents.
2. Open the Contents folder, and then open the Resources folder.
3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open.
4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents.
5. Open the Contents folder, and then open the Resources folder.
6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder.
7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file:
2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder.
3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open.
5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder.
6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder.
7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder.
8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.)
Compile and install.
I know its a lot, but Adobe is a complicated program:) Source(s): http://kb.adobe.com
Aug 10, 2009 | Adobe Photoshop Elements 2.0
Scracth disk is full
The Photoshop scratch disk is your hard drive. Photoshop uses your hard drive as temporary "swap" space, or virtual memory, when your system does not have enough RAM to perform an operation. If you only have one hard drive or partition in your computer, then the scratch disk will be the drive where your operating system is installed (the C drive on a Windows system).
You can change the scratch disk location and add multiple scratch disks from Photoshop Preferences. Many power users like to create a dedicated hard drive partition for the Photoshop scratch disk. Although Photoshop will function with a single scratch disk on the system partition, you can improve performance by setting the scratch disk to be the fastest drive in your system. Other useful guidelines for setting scratch disks are to avoid using the same drive where your operating system is installed, avoid using a drive where the files you edit are stored, and don't use network or removable drives for a scratch disk.
If Photoshop is shut down improperly or crashes in the middle of an editing session, this can leave fairly large temporary files behind on your scratch disk. Photoshop's temp files are typically named ~PST####.tmp on Windows and Temp#### on Macintosh, where #### is a series of numbers. These are safe to delete.
If you're getting an error message that the scratch disk is full, it means you need to clear some space on whatever drive is defined as the scratch disk in Photoshop Preferences, or add additional drives for Photoshop to use as scratch space.
Dec 29, 2008 | Adobe Photoshop 7.0 for PC
Scratch & windows error
You must change the location of Photoshop's primary scratch disk to a different HD or other HD partition. You can do this using the Windows Explorer
Oct 28, 2008 | Adobe Photoshop 7.0 for PC
Adobe Photoshop Elements 2.0 for PC Logo
41 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
