I have a Toshiba Satellite C655. The screen is malfunctioning as you can see. The screen has 3 vertical striped lines which has divided the screen into separate parts. The cursor will not pass through
  • 3 Answers
Did you damage your screen (i.e. step on it, wet it, ect.)? If you did then you might have to take it in for repair. Regardless, you might just need to call a troubleshooting or help line/number, for that particular brand ( i.e. dell, toshiba,ect.)
Posted on Jan 02, 2013
2 Suggested Answers
  • 10 Answers
SOURCE: I have a Toshiba Satellite C655. The screen is malfunctioning as you can see. The screen has 3 vertical striped lines which has divided the screen into separate parts. The cursor will not pass through
Try updating the video driver on the laptop. The issue could be software related.
Click on the following link to go to Toshiba's downloads page. Select your laptop model and then download the newest video driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Posted on Nov 05, 2012
Vertical lines on screen
Desktopsbyduck-Computers 225-290-5733
682 Wildcat Creek Rd, Ellijay, GA, 23455..I believe after update to newest video driver you still have the problem call about a possible screen replacement:
Apr 17, 2014 | Toshiba Satellite C655-S5540 Laptop...
Connecting charger and letting charge for sometime...charging light doesnt turn on and laptop doesnt turn on...any advise?
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-65w.html
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-3-95a.html
Nov 07, 2012 | Toshiba Satellite C655-s5140 Laptop
Had this problem once and a found out how to fix it. It's a hardware prob, to fix this prob your Pc has to be on while doing it, this way you can see if the problem has been fixed or not. You need to unscrew all screws on the shell of the screen. Then you remove the two screws found at the bottom of the screen they are found close to the hinge.
Now the back part of the shell should be off. once that is off just disconnect the silver cable that is connected to the screen and reconnect it again and bend and squeeze it to see if it is a shortage in the wire. If not remove it once more and reconnect it again. (should be fixed now)
Use a strip of tape to hold it in place and your done. use it for a couple hours to ensure it fully functional then put it back together and you're done.
Nov 05, 2012 | Computers & Internet
Toshiba Satellite C655-S5125
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
11th heading down - Satellite A10. (A10 in Blue)
Go down to the second line, (Begins with A350D in blue), and click on -
C650. (You can also click on C655D )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
Now what is the problem? Post in a Comment.
Apr 21, 2012 | Toshiba Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
Feb 16, 2011 | Toshiba (P000257700) Microphone
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
