Question about Philips 50P8341 50" Rear Projection Television
TV will not turn on
Remote or button on tv will not turn on tv. If the tv sets for a while sometime it will come on but will not go off (have to unplug for it to go off) then will not come on for a period of time
    Problem Solver:
  • 7 Answers
The common failure for that symptom is the SSB or small signal board, Philips p/n# PH3912725871 or 313912725871
Bill
Posted on Jan 27, 2009
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
Aug 20, 2011 | One For All URC 7740 Remote Control
Can not turn on tv.
Just press the buttons on the TV randomly, sometimes this combination works in starting the TV w/o a remote. After that use the remote for the dish to flip channels, but you will have to set the sound manually from time to time.......sodeep
Jun 13, 2009 | JVC AV-32120 32" TV
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Remote IR Reciever Problem
Micro might be confused, have you tried cycling the power to the set?
May 30, 2007 | Zenith IQB32B84R TV
This sucker will not turn on.
Check the buttons on the TV set and make sure they make a small detent like click to them, as sometimes these buttons will stick and cause the entire set not to work. Good Luck
Mar 25, 2007 | Panasonic CT-36HL43 36" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Auxiliary button on tv remote (I believe) needs off and I can't get figure out how...
The remote should have TV, VCR, AUX and maybe CABLE buttons at the top, one of which will light up when any button is pressed. Since it is a universal remote, the button at top lights up to let you know what mode it is in. If the AUX button lights up when any button is pressed, it means the remote is currently set to the AUX mode. To set it back to TV, simply press the TV button at the top. This puts the remote back in the TV mode and the TV button should now light up when any button is pressed. If that works and you are using a cable box with that set, then make sure the TV is on channel 3 by pressing 3 ENTER.
Sep 21, 2006 | Zenith C27A24T 27" TV
Philips 50P8341 50" Rear Projection Television Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
