Question about NAD C370 2-Channel Amplifier
How to replace internal fuse for nad c370 amp
No power no lights checked power suppy and plug fuse
  • 4 Answers
SOURCE: NAD 370
Hi There is no circuit breakers inside. close to front panel on a left side under plastic cover is fuse (AGC type) . Before you change fuse look at four filter capacitors in the middle of unit!!! (close to power transformer on pcb) If they are white do not change the fuse and get unit to good service center( it must be someone who knows what they doing!!!) If the caps are different color (black ,purple) you can try to change fuse. Once again if capacitors are white do not use unit-fire hazard!!!! I'm long time service guy for NAD so trust me on this one Dariusz  dariusz70@verizon.net
Posted on Feb 13, 2008
  • 31 Answers
SOURCE: NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Posted on Sep 17, 2008
  • 24 Answers
SOURCE: No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Posted on Dec 29, 2008
petraman7
  • 1175 Answers
SOURCE: NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Posted on Apr 11, 2009
Grubhead
  • 5190 Answers
SOURCE: my nad amp wont turn on - i've checked plug fuse so it must be something inside - was told it might not be worth fixing but i wuld like toknow what it is so i can at least decide. it's only 2 years ol
Yes it could be the internal fuse. If your lucky it might have just failed on it's own!
Posted on Jun 02, 2009
NAD C370 distortion
Check first if you got +68/-68V on amp module left and right on contact CZ302 and CZ402 pin 2 & 7. Often the -68V is missing. This is caused by faulty transistor Q713 in +68/-68V power supply. It's a 2SA872.
Oct 31, 2013 | NAD C370 2-Channel Amplifier
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
No power at all
im guessing you have opened up the case of the amplifer
look in the area where the ac plug plugs into the box.
you may have to remove some of the boards to get to it
the main internal fuse should be next to the place where you attach the ac plug
also check the main wire wires that go into the main board from the power supply check for voltage
May 11, 2010 | NAD C370 2-Channel Amplifier
Nad c 370 no power
You need to look inside. There will be a fuse inside too. If your lucky it will restore the amp once replaced, but if it blows again you have a fault. You can track it down yourself if your any good, you might even see a burnt out part when looking for that fuse, otherwise get the repairman in.
Sep 20, 2009 | NAD C370 2-Channel Amplifier
Myc370amp turns its self about 15seconds after turn on
Replace 3 capacitors on the protect printboard. (located near the outpt terminals) 50V electrolyt: 4,7uF, 47uf and 10uF. And move the big diode to the back of the printboard (the heat from the diode dries out the capacitors)
Work in 9/10 times ;)
Aug 12, 2009 | NAD C370 2-Channel Amplifier
Apr 11, 2009 | NAD C270 2-Channel Amplifier
User manual here
Dec 29, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
150 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
