Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Gear slipping - Bissell SpotBot Robotic Wet/Dry Vacuum
  • Bissell Master
  • 18,408 Answers
Is it slipping or as the teeth on gear broke
http://www.vacsite.com/en/bissell-/002V-2036658.html
Posted on Jan 02, 2013
Hoover carpet cleaner brushes wont spin
First i would be checking for a mechanical restriction stopping the brushes from spinning like hair or similar wrapped around the brushes and jamming them, if all is clear it could be a belt broken or slipping, a stripped gear or an electrical fault, depends on what type of drive system the brushes on your particular vacuume cleaner uses. Hope this is helpful.
Aug 17, 2017 | Hoover Vacuums
Brush does not go dwon to floor at all
The landing gear may have slipped into the wrong position. Take it to your dealer.
Jan 21, 2014 | Dyson DC25 All Floors Bagless Upright...
Sometimes while I'm vacuuming, the front of the vacuum makes a horrible noise. If I lift up the front end, it stops. Any ideas?
I just cleaned the small metal drive gear inside the brush housing. That solved my problem. It seems that some junk can build up in the drive gear which makes the belt slip on the gear. That is horrible noise you are hearing.
Mar 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I accidently sucked up a pen cap and it stopped working then it began smoking and the belt snapped??
Take the pen cap out of where it is stuck and replace the belt. Most likely the smoke was from the belt slipping around the gear and getting hot. Did the smoke smell like burning rubber?
Oct 01, 2009 | Bissell 3576 CleanView II Bagless Upright...
My Dyson DC07 Makes a loud sound like a belt slipping over a cog. Sometimes it will go for days without doing it. Other times it will happen every minute or so. It
Once again check for blockages in the brush bar compartment.The brush bar should spin freely
The clutch may be slipping to protect its self when their is something stopping it from from turning
Aug 22, 2009 | Dyson DC07 Full Gear Bagless Upright...
Hoover dual windtunnel model U8149-900 series Y 12.0
this model has 4 brushes to replace. they are connected by gears
they have a bad habit of stripping so get all 4
after you pull off the bottom plate there will be retainers on the outside ends
Nov 30, 2008 | Vacuums
Brushes do not spin
The manual suggests cleaning the filter screen near the brush assembly. This is located on the bottom of the unit. In cleaning this it did not successfully help. I then proceeded to take the cover (blue) off the motor an brush drive and worked my way to the gear assembly. This is where I found the actually problem.
The problem: The brushes are driven by a turbine wheel operated with suction from the vacuum. In my unit the turbine and bearings became loose or slipped to the point that the worm gear lost contact with the additional gears that drive the brush. When resetting the assembly so that ample contact is established the unit began to operate fine.
This can be complicated to explain and illustrate therefore taking the unit in for repair is recommended. If you are confident in repairing the unit yourself then go for it.
Jul 28, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Bissell vacuum blet smells burnt
It is probably slipping and needs to be replaced. Also check the brush roll, make sure the ends are ok and turning freely, if not, then replace it also.
Apr 13, 2008 | Dyson DC14 Full Gear Bagless Upright...
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
