Question about Keurig Mini B31 Plus Red Coffee Maker
Cant get my keurig b31 mini plus to use water it just sits there
Its moving very little water very slowly
    Master:
  • 240 Answers
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Posted on Nov 25, 2013
2 Suggested Answers
supernova278
  • 1932 Answers
SOURCE: I have a brand new
After heating it switches off.This is because once the water get heated up ,It activates a cut off switch which stops the heater.This is a safety feature.
Can you be specific.? shuts off in the sense.?After that you can not use at all or can use.?
Thank You
Posted on Sep 29, 2010
Keurig B31 Mini Plus Brewing System not working
There is a transformer that take the 110 voltage and reduces it to 13.8 or 14 volts depending on your unit model, it runs an electronic board or little computer in the coffee maker. It's the brains of the coffee maker. I would say you fried the transformer and possibly the electronic board if the high voltage made it past the transformer. I have replaced the transformer in our sons Keurig and that fixed his problem but he didn't plug it into 220v. The transformer is not expensive, an eBay item at around $15 or so. Taking the unit apart is not an easy thing to do. But if your handy you could figure it out and test the transformer to see it it's putting out the right voltage. Just check the voltage tag of the one that it came with so you can order the right one for your pot.
Apr 21, 2014 | Keurig B31 Mini Plus Brewing System
Keurig mini plus b31 only half cup of the water dispenses
Reset the out-flow and dispensing format. See Manual for instructions.
Feb 16, 2013 | Keurig B31
Keurig mini keeps asking to add water
Needs cleaning and reset the system with a full flush and Calc.
Feb 04, 2013 | Keurig B31 Mini Plus Brewing System
Our brand new keurig mini plus wont heat or dispense water
I had the same problem with my Mini ! I also had this problem with my last Mini which was given to me and I tossed out. So I replaced with the new one which just went on the fritz. Called Keurig who were very helpful and told me to descale, but I explained the machine is almost new. So I prodded them for what else could cause the problem and its water that is too cold.
Turns out the problem is that I was using very cold water and the machine can sense the water is cold and will not heat. It does not heat so it wont damage the heating element. I was using 40 degree water from the fridge.
My symptoms were: I would fill it, that the blue light would flash, I would push the button, then the red light would flash and then nothing it would shut off after a while. Now with not so freezing water it works fine!
Hope this helps as I threw out a good machine because the water was too cold!
Jan 22, 2013 | Keurig Mini B31 Plus Red Coffee Maker
Manual for Keurig B31
Call 1-866-901-2739 for a manual.
Aug 23, 2012 | Keurig B31 Mini Plus Brewing System
Keurig B31 one cupcoffee maker users mannual
Keurig calls the B31 the Mini Plus Brewer. The manual is available from the Keurig Customer Service site: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The direct link to the English version of the Use and Care Manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/B31%20UCG%20ENG_FRE.ashx .
I hope this helps.
Nov 08, 2011 | Keurig B60 Coffee Maker
Keurig Mini B31 Plus Red Coffee Maker Logo
193 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
