Question about Dell Ethernet Card Network Adapter
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  • 24 Answers
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Posted on Jan 21, 2009
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
My zyxel P-660HW-T1 v3 has the restart problem.. When i try to restart modem from browser by 192.168.1.1 and tools then everything goes smoothly till there then after i clicked restart option, It seems ok...
Have patience! It can take the modem/router 30 to 90 seconds to _FULLY_ restart, and to synchronize with the Internet Service Provider's network. Meanwhile, your computer may show "no network connection" or "network cable unplugged". Then, it takes 15 seconds for your computer to synchronize with your modem/router -- that 15 seconds is what you're experience if you unplug the cable, and then "last action to plug it".
Apr 01, 2011 | Computers & Internet
Dell truemobile 2300 shows connected to internet, but isn't
When you reset the router, did you first shut the router down, then unplug the modem (wait 30 seconds), reconnect the modem (wait for all lights to go to "normal mode"), reconnect router to power, check for activity light on modem, wait about 30 seconds after all is powered up? If not, try that sequence and let me know if it works.
Mar 05, 2009 | Dell TrueMobile 2300 Router (000001)
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Dell Ethernet Network Adapter not being recognised
                      or
                                         (OR)
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Dell Inspiron 5100 Internet Access
Do you have your computer connected to your wifi network and your ethernet cable at the same time? Try having it connected to only one and see if that changes anything (ie, keep the wireless on and unplug the cable, or keep the cable plugged in and disable the wireless - if your laptop does not have a button/switch to turn off the wireless, you can do so by going to your network connections area from the control panel, right clicking on the wireless internet icon, and selecting disable.)
Nov 08, 2007 | Toshiba Satellite A75-S226 Notebook
Dell Ethernet Card Network Adapter Logo
453 people viewed this question
Alun Cox
