Question about Whirlpool Duet GHW9150P Front Load Washer
HOW DO i REMOVE INK FROM THE INSIDE OF MY DRYER?
    Problem Solver:
  • 10 Answers
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Dan
Posted on Aug 06, 2009
  • 640 Answers
You really cant ,,i would just let it dry,,this is why,,because any product that will remove the ink will aslo remove the enamel,,and with out that coating ,,your chothes will get gray stains from the raw metal once the ink dryers it will not come even on the white clothes...
Posted on Jan 20, 2009
How to get ink stains from the inside of a dryer?
Hi jchbell
Take the dryer out to a well ventilated area.
Wear gloves, use a rag dampened with Lacquer Thinner and hold your breath alot...
Wipe the ink stains with the Lacquer thinner and it will remove most all of the stains to the rag.
Please take time to rate me
Sep 05, 2011 | Dryers
A pen exploded in the dryer and I cannot remove the ink from inside the drum.
Hello 5.....
  1. Turn the dryer off and remove any laundry from inside the drum.
  2. Unplug the dryer.
  3. Dampen a paper towel with rubbing alcohol.
  4. Scrub the ink stain with the dampened towel. Repeat, if necessary, with a fresh towel dampened with rubbing alcohol, to remove all the ink.
  5. Wipe the area with a cloth dampened with water, to remove any alcohol residue.
  6. If the stain persists, soak a white rag with rubbing alcohol or hairspray and scrub the stain. It may take repeated applications to dissolve the ink. Joe
Thanks for choosing Fixya!
Mar 08, 2011 | Amana Dryers
Dried ink in dryer
Ask a copier repair person to give you some D-Ink.
Jun 10, 2010 | Whirlpool LER4634J Electric Dryer
An ink pen accidentally got in with the clothes we were drying. So now ink stains spewed around the drier. Anything that can be done to clean the mess up?
Hello. I can help you. This is what I recommend - To remove ink stains from your clothes dryer, place 2 cups of bleach in a bucket, then fill the busket halfway with water. Take some old towels and soak up the liquid in the bucket. You don`t want the towels to be dripping wet, just damp. Place them directly into the dryer to remove the ink and run an entire cycle. Repeat if necessary. When you feel you have removed the ink sufficiently, place an old dry towel in the dryer to make sure that you removed all of the ink. Generally it takes about an hour to remove all of the ink.
Nov 28, 2009 | Dryers
INK PEN IN DRYER INK MARKS ALL IN DRYER HOW DO REMOVE INK
use a cotton ball with a small amount of Eucalyptus oil and wipe clean.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Whirlpool GEW9250P Electric Dryer
INK PEN LEFT IN DYERS NOW INK MARKS ALL IN DRYER
try some OOPS Just make sure before you run drye again, you have wiped out inside because OOPS s flammable.
Sep 12, 2009 | Whirlpool LER4634J Electric Dryer
How do I remove ink stains from the inside of my dryer?
You can try to use nail polish remover or wd 40 .Then clean after done.Make sure it is cleaned really good after your done.If still on there it may be die from blue jeans or bounce then it will not come off
hope i helped:)
May 17, 2009 | Dryers
How to remove ink from dryer
None of the chemicals you describe should be used. The heat or spark from the motor could cause a explosion.
Put some old laundry material in there and run it multiple loads with no heat it will eventually wear it off.
Apr 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Ink in the dryer
Rubbing alcohol will work to remove most of it if you use alot of elbow grease.
What I found worked the best and quickest was a Mr Clean Magic Eraser wetted acetone nail polish remover. Leave the dryer door open to let it air dry, then put a couple of white towels soaked in bleach water and run the dryer on a non-heat cycle to remove any remaining smudges.
To be paranoid, I then ran the same towels through the washer and dryed them on high heat to make sure there was no ink I missed that might ruin any further clothes.
Mar 28, 2008 | Roper REX4634KQ Electric Dryer
Ink in Dryer
wet towel add about 1/2 cup of bleach, put in dryer.... the ink completely gone in less than 10 minutes
Sep 28, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
