Question about Acer Aspire AM1610-U1201A PC Desktop
Acer Aspire AM1610-U1201A Update Bios - Acer Aspire AM1610-U1201A PC Desktop
2 Suggested Answers
z89s
  • 225 Answers
SOURCE: AM1610 U1201A audio drivers for xp
have you tried looking on the acer website? go to http://gd.panam.acer.com/home/ if you havnt tried there i dont see a audio driver for xp but i see one for vista you could try using vista's and see if that works if it doesnt then go to start menu right click computer click manage go to device manager and right click on the audio its not reconizing and click update driver then click search on web if it doesnt find it then try finding it on a drivers site or when your in device manager do what i just said but instead of clicking search on the web click browse my computer for driver once you download the vista driver online use that as the driver just click browse my computer find the vista file and install it wont install the program it will just install the driver in the vista file that should work
Posted on May 28, 2009
Computers comes on and it goes to verifying dmi pool data and comes back with error msg....or after its been unplug for awhile it goes back to normal but after awhile it freezes up and then when hard reset...
During the verifying dmi pool data stage of boot, the Motherboard is trying to 'poll' the devices in your PC. This is governed by the BIOS settings in the CMOS chip. It is possible to have a defective CMOS chip, but rare. It is possible to have invalid or corrupted BIOS data in the CMOS chip--which can be cleared to a 'default' state. You stated that if it is unplugged for a time, that it will 'go back to normal', the corruption is being reset. If your BIOS is set to be 'shadowed into memory' for faster loading, then Disable that feature and see if the problem is corrected.
You would need to open the Tower and locate the Motherboard Model (like P5SD2-VM) then look on the internet for the Manual for that model and see if there are any BIOS settings for the 'shadowing' of the BIOS.
This problem can also occur if there are SATA drives in the Tower and 1 or more are not being detected, (depending on the BIOS MFR,) this happens to older boards with SATA ports, much more than late model ones; so while you have that side-panel off, remove and re-connect all of your Power and Data cables to the Hard drives and the Optical drives, (CD/DVD.)
Jul 31, 2011 | Acer Aspire AM1610-U1201A PC Desktop
I can not fix recovery factory my pc
If you laptop was not supplied with a Windows CD then most likely the hard disk on your laptop has a recovery partition on the hard drive and you can restore your laptop back to the condition when you first purchased the laptop using this recovery partition.
Acer can also supply a recovery CD for your model Acer if you request one. This is needed when the hard disk has failed.
Read your laptop documentation for the instruction on the restore procedure. You also get this information from Acer's WEB site.
Apr 25, 2011 | Acer Aspire AM1610-U1201A PC Desktop
My Toshiba Laptop monitor just died and I want to transfer the data (windows xp) from the hard drive onto my Aspire AM1610 desktop (windows vista). How can I do so?
1. Remove the hard drive from Toshiba (most probably its a 3.5" one)
2. Borrow or purchase an external box which supports IDE 3.5" drives
3. Connect to USB port of Aspire
4. From under "My Computer" you should be able to see some contents of the drive
5. To access all contents, you need to change owner ship under folder options.
Good luck
Dec 05, 2010 | Acer Aspire AM1610-U1201A PC Desktop
My acer am1610-U1201A won't connect to the internet. I have the modem and router hooked up, ethernet cable and all other cables hooked up appropriately, and my computer says it's connected to a "local...
right click "MY NETWORK PLACES " desktop icon.
click "PROPERTIES"
click the Local Area Connection.. "Properties"
click "INTERNET Protocol (tcp/ip)
at the lower part,, click "properties"
thru the "General" tab
click the OBTAIN an IP Address automatically
click the Obtain DNS Server Automatically
then OK..
see to it that the name of the WORKGROUP same in the name of the server computer..
right click the "My COmputer"
"PROPERTIES"
"COmputer NAme"
...if they the same , you can access the net now.. Thanks for sharing your problem in fixya.com
Sep 14, 2010 | Acer Aspire AM1610-U1201A PC Desktop
Power switch will not work
Maybe your power supply is defective, try to
check them
Jun 28, 2010 | Acer Aspire AM1610-U1201A PC Desktop
My acer aspire w/ windows vista won't connect to the internet anymore
Try a system restore
Start>>All Programs>>Accessories>>System Tools>> System Restore
then set to a previous date, when your internet was working
Nov 19, 2009 | Acer Aspire AM1610-U1201A PC Desktop
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Try this link
http://www.acer.co.ae/acer/service.do?LanguageISOCtxParam=ar&miu10einu24.current.attN2B2F2EEF=3736&sp=page15e&ctx2.c2att1=24&miu10ekcond13.attN2B2F2EEF=3736&CountryISOCtxParam=MI&ctx1.att21k=1&CRC=4250700633
Or entrer the site
and find the links Service & Supoert after that click and Drivers Download. Look for the model of your machine and download the drivers.
I hope be helpful
May 28, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Acer Aspire AM1610-U1201A PC Desktop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
