Question about Oreck Dual Power Electric Floor Sweeper Bagless Upright Vacuum
Hi, I have a oreck dual power sweeper vacuum DP460 and I am looking for replacement filter for it. Does anyone know where I can find one?
It has the dust cup with the filter bag. I have looked other places even on oreck website and can't seem to find it. I did get some filter from another place one time but they weren't the right ones. Even though I gave the right model number. DP460 Thank you for your help Sharon
  • Oreck Master
  • 18,392 Answers
Have you tried this site click the link below
http://www.vacpartswarehouse.com/Oreck-DP460-Electric-Broom-s/2975.htm
Posted on Jan 02, 2013
  • SHARON HOWE Jan 03, 2013
    Yes, I tried that sight and nothing! But, maybe I'll try again thank you!
VacuumRepair
  • 438 Answers
SOURCE: vacuum bag busted
Greetings from GoVacuum.com,
Yes, you certainly can take off the outer bag of your Oreck and wash it in the washing machine. You DO NOT however want to put the bag through the dryer!!!!! Just hang the bag outside, and let it air dry. It is important to make sure that the bag is 100% completely dry before you use the machine again. If the bag is wet, it will cause dirt to turn to mud in the bag, and probably cause a foul odor when you use the bag.
There are 2 different types of bag systems with Oreck vacuums. The one pictured below is the older style that uses a metal clamp to hold the bag in place. The newer docking system, will be a white plastic clamp that holds the outer bag in place. They both will be removed the same way however. Simply take a screwdriver and pry off the clamp;
Once you have removed this clamp, simply pull the outer bag off. Once it has been washed, and the bag is 100% completely dry, put the outer bag back over the bag housing as far as it will go. When you put the clamp back on, it is imperative that the clamp go behind the plastic ridges, to ensure that it is tightly fastened. If the clamp is not put on correctly, this will cause the inner paper bag to fall off during vacuuming. Make sure that the clamp is in the right position when putting the bag back;
If you have any further questions, please feel free to email them to me. I really enjoy sharing my knowledge an passion about vacuum cleaner, and vacuum repairs. We do stock all Oreck parts, so if you need any parts, please let me know.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 15, 2008
ukvacfan
  • 328 Answers
SOURCE: Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Posted on Nov 18, 2008
SOURCE: Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
Posted on Dec 22, 2008
SOURCE: Oreck Vacuum Cleaner problem (upright)
the belt has stetched and needs changing.
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
Posted on May 29, 2009
How to attach bag docking to oreck sweeper
docking system fits over fill tube elbow.
You can see a picture here:
Replacement BAGS to fit Oreck Dock 8pk
The docking system can be found here:
Oreck Docking System R0011 genuine
800-775-6586
GoodVac com
Jun 28, 2014 | Oreck XL2200 Bagged Upright Vacuum
Jusy shut off while using
Your sweeper may have overheated. I don't know what brand you have but I hope you weren't trying to vacuum pine needles from the Christmas tree. Pine needles are sticky and will clog up any vacuum sweeper. Check your sweeper to make sure the tubes (hose & pipes that carry dirt) are clean and clear. I used to service Oreck vacuum sweepers.
Dec 30, 2013 | Eureka AirSpeed Bagless Zuum
2013 Oreck Vacuum . How can I check to see if it is stopped up?
If it scatters the dirt then it's definitely clogged up at the nozzle just behind the roller brush. Turn the sweeper upside down and stand it on the handle. Then look under the roller brush. I have two Oreck's in my house. You can take a screwdriver to loosen the clog and dump out the dirt. Don't try to pick up pine needles as these are sticky and will quickly clog up any vacuum sweeper.
Dec 29, 2013 | Oreck Vacuums
Assembly for oreck base plate
You don't say what the problem is with your Oreck sweeper? You can go to www.oreck.com and look for repair service for help.
Dec 28, 2013 | Oreck Vacuums
Oreck Dual Power Electric Floor Sweeper Bagless Upright Vacuum replacement for filter over the plastic
Dear Sir:
Please follow the instruction from your section troubleshooting from user manual. or go www. fitness.manualsonline.com or www.retrevo.com
or go to directly to the company from the Vacuum. and follow steps.
God bless you
May 26, 2012 | Oreck Dual Power Electric Floor Sweeper...
I have a Oreck DutchTech 1400 vacuum, the power nozzle does not shut off the Vacuum and I can not adjust the power of the motor, looks like the PCB board is defective, does anyone know where it can be...
It could be your hose, your PCB, or you RCM Swivel. Oreck no longer makes these vacuums or manufactures these parts. they are super hard to find the only places that would have them are old Oreck stores that have been around for a while. but most of the oreck stores do not carry any Dutchtech parts any more. Now They Sell Miele vacuums with are the top of the line as far as canisters go in the vacuum world.
Sep 03, 2011 | Oreck DutchTech DT1400B Canister Vacuum
Hi, I purchased a used Oreck BB870-AD canister vacuum cleaner, but it didn't come with the manual or any bags. Can you tell me where I can find the manual & what type of bags do I need?
The manual is available as a PDF here: http://www.oreck.com/Owners-Guides . Scroll down to the Canisters section and then select the link for the Compact Canister vacuum.
The replacement bag that you should use is: Oreck Replacement Treated Filter Bags (12 pk. with
1 Micro Filter) No. PKBB12DW which cost $14.99 for each package from Oreck. On the Oreck site, these are the Hand-Vac Bags. See: http://www.oreck.com/Hand-Vac-Bags to order them online.
I hope this helps.
Mar 21, 2011 | Oreck Vacuums
Can't get the filter on
Good morning,
Here is the manf. guide to the DP460:
http://www.oreck.com/PUG/Power-Broom.pdf
The filter bag can be removed from the frame for rinsing/cleaning, and the bag can just be refitted in the frame. The frame only fits one way onto the vacuum.
Let me know if you need more clarification (the manual also includes pictures). Please rate this solution! Thanks!
~PCF
Mar 05, 2011 | Oreck Dual Power DP460 Upright Vacuum
Oreck Dual Power Electric Floor Sweeper Bagless Upright Vacuum Logo
291 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
