Question about Canon i850 InkJet Photo Printer
Printer will not print black ink
Even with a new black cartridge, my printer will not print any black text. The printer is 4+ years old and has worked fine, but suddenly started having problems.
  • 7 more comments
  • sashy Nov 21, 2007
    The printer is not printing black ink. Running the nozzle check operation resulted in missing black pattern. Many attempts of deep cleaning did not result in any improvement.
  • bjbs2 Mar 20, 2008
    My Canon i850 printer will not print black ink. I have run the deep clean several times but it still won't print. Anybody know what is causing this? I put in a new cartridge and it still will not print.
  • freddie96 Mar 24, 2008
    fitted new print head ANS all new CANON cartridges and nothing will print. Any thoughts as deep cleaning still produces balnk pages
  • freddie96 Mar 29, 2008
    Cleaned ink soak pads, fitted new print head, fitted new Canon inks, deep cleaned etc and nothing will print
  • Anonymous Jun 21, 2008
    Black and white test prints some lines and not others. Changed black cartridge but it still does not work. Colored photos seem to print fine. Tried changing printer set up but it still does not work.
  • bolan3022 Aug 10, 2008
    black ink doesnt print. all other colors do
  • Anonymous Aug 24, 2008
    Exactly the same problem with black not printing on the Canon i850. Changing the paper type from Plain Paper to something else does seem to fool it into printing, however. A hassle but at least it works....
  • Anonymous Sep 14, 2008
    Prints but does not really print, even witha new blackink catridge!
  • William McGill Apr 10, 2018
    Thanks for the tip! It worked for me.
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Posted on Jun 15, 2008
I had the exact same problem, so I changed the paper type (in printer options) from plain to "photo". Now the black text is printing fine. And it is using the black text cartridge to do so. Sensitive little printer huh? The Canon i850 is suposed to be a photo printer, so I think that is how Canon attempts to justify black text printing NOT being a default mechanism. Still though! Pretty hard to believe that they wouldn't predict this usage situation and make it a default. Good luck Draeden. Canon- your market research people are fired!
Peace, love, and soul ya'll. I'm up out dis beezee like I stole somethin'.
-Sef
Posted on Apr 01, 2009
  • fabulouslyfi
    fabulouslyfi Nov 21, 2012
    great advice. tried it and guess what you saved me some dough. thanks dude.
Pop out the printer head by pushing in on tab in front, lift up holder and remove head. I soaked it in rubbing alcohol--just enough to cover screens, about 5 min. Rinse with water till clear, dry and reinstall--Worked great!
Posted on May 08, 2009
  • Jcallepi Aug 31, 2010
    It's work for my printer Thanks
Your printer might be set different than plain paper setting. We had the same problem when ours was set for photo glossy plus while using plain paper.
Posted on Mar 23, 2008
    Genius:
  • 2,985 Answers
Time for a new printer then me thinks take a look at www.fixyourownprinter.com
Posted on Jun 25, 2007
I had the same problem. My color cartridges printed fine, but the black did not print -- just blank. I called Cartridge World and they suggested the problem could be a clogged line. They recommended a nozzle rocket cartridge, sort of a "Drano" for print cartridges. I brought in my black cartridge and they dumped the black ink and filled it with a cleaning solution (at no cost). I placed this back into the printer and proceeded to start printing multiple pages in black in order to allow the solution to move through the lines and break up any clogs. It took about 30 pages, but the light gray color finally began to come through (it should look light gray, not black). I was told to try and use the entire cartridge before replacing with a regular black ink cartridge. Worked great!
Posted on Aug 06, 2008
Also had this trouble with my Canon MP370 so changed the paper type to phototype glossy and it works - thanks so much!! Think I will be able to load this so I don't have to set it every time.
Posted on May 11, 2010
I was having the same problem, but i resolved it by going into properties and changin from printing in color to black ink only. it worked immediately..hope this helps! =]
Posted on Aug 30, 2009
  • 68 Answers
SOURCE: Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Posted on Sep 21, 2007
SOURCE: Printer will not print black ink
Joed911
  • 4338 Answers
SOURCE: will not print black ink text
go through the step-by-step solution and repair procedure on Kodak's site. Click on the first item on this list:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7269&pq-locale=en_US&hidefocus=false
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 02, 2009
  • 373 Answers
SOURCE: Dell 922 all-in-one won't print
call dell tech department
Posted on Feb 10, 2009
  • 103 Answers
SOURCE: I am not able to
On the printer
Press Menu > Clean Printhead
Try to print > If same result > Then call Kodak 18004216699 and order a free printhead
The nozzels on the printhead are blocked
Posted on Feb 22, 2010
I have a HP 8259 printer and it indicates the yellow print cartridge needs to be replaced even when i install a new cartridge. It will not let me print in color or black/grayscale. I have had the printer...
Older printers can do funny things. It is probable that the little copper contacts on the ink cartridge are not making good contact with the printer which is giving bad information to the computer that the ink cartridge is empty. A two year old printer may have some corrosion on the printer's contacts. Remove the ink cartridge and use a soft pencil eraser to clean the printer's contacts.
Oct 10, 2010 | Office Equipment & Supplies
My printer will not print text.
Did you try and change the ink cartridge mode from color + black to color, or vice versa? Another thing you can try is to "prime" the ink cartidges by taking them out of the printer and gently pressing on the print nossels to get the ink flowing, then put the cartridges back in the printer.
http://www.techwaredist.com/repairshop.asp
Dec 09, 2008 | Primera Technology Bravo II DVD Duplicator...
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
No text
Check that your black ink cartridge has ink inside, eventually try a new cartridge , as ink may have dried up in old cartridge.
If you use a new cartridge ensure you removed cellotape from cartrige.
If cartridge is ok, then it is printer nozzle/head for black ink.
In this case do nozzle check / head cleaning in printer tools a couple of times.
If problem persist you may need to check and clean printer's head with cotton and solvent.
regards
Mar 20, 2008 | Computers & Internet
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
3,385 people viewed this question
old marine
old marine
