Question about Keurig Elite B40 Coffee Maker
B40 problems started running on its own, then tripped electrial breaker
  • 1,511 Answers
Short was developed on the circuit board or line attachements.
Posted on Feb 06, 2014
Actives art fridge/freezer tripping mai circuit breaker, been running since 9.30pm, and tripped it out at 9am this morning
get in a technician as there may be a problem start/run capacitor that has overloaded and tripped the breaker or a compressor failure
Mar 19, 2017 | Refrigerators
The outside unit is running, fan is working, but the furnace will not start... it's getting hot in here!
There are many reasons why the 'inside' fan motor could not be running, however, the obvious one is that the breaker (to the inside unit) has tripped, and needs to be reset.
Hopefully, that might be your only problem. Sometimes they (breakers) will 'trip' for no reason, although most of the time a 'tripped breaker' is an indication of another problem.
If resetting your breaker does not cause the motor to run - then your best solution would be to have a AC Tech troubleshoot it to find out the cause.
Hope this has helped.
Aug 05, 2011 | Ruud Heating & Cooling
NO POWER TO UNIT
Is there power to the outlet itself?? If not see if you have a GFCI (ground fault circuit interupter) outlet near by ( it is an outlet that is usually shaped different than the other outlets) this outlet has two buttons on it "trip" and "rest" press the "rest" button this may turn the power on to the coffee outlet.If still no power, check to see if the breaker in the house power panel is tripped, if so rest the breaker by moving the switch on the breaker to the "off" position then back to the "on" position. This should reset the breaker, it trips again there is a problem that needs a more skilled person to assess. If this doesn't work there could be a problem with the coffee maker itself and unless you have the equipment to test and repair this you may be out of luck.
Apr 16, 2011 | Keurig Elite B40 Coffee Maker
Maytag Neptune dryer will not turn on...has at least 110 electris coming to it... shows a digital display .8.8 ...
you need 240volts for it to run and heat,the timer and motor are each on their one side of 110volts and the element needs 240volts to heat,so if the motor runs or the timer runs but not both and it doesnt heat your missing one of the 110 to 120volt phases,check the homes power panel it will have either a tandem pole 30 amp breaker or 2 30 amp fuses and one of them will be bad(open) the breaker may look like its not tripped,but sometimes one leg will open and not show,turn it off and back on then check for 240volts at the dryer
Jan 09, 2011 | Maytag MDE5500AYW Electric Dryer
The garbage disposal & overhead sink fixture run to the same Square D Qob120 1pole 15amp 120v Circuit Breaker . After a week of consistentlu tripping, the breaker won't allow itself to reset. ...
I would start by replacing the breaker. If a new one trips then check ground and wiring. If it still trips then there must be a problem with the garbage disposal. let us know
Sep 21, 2010 | Square D Qob120 1pole 20amp 120v Circuit...
My heil heat pump has been tripping circuit breakers. It might run 8 hours to two days before it trips. I replaced the breaker. They put a hard start on the compressor. Now they say the next step is the...
Have you noticed what the outdoor temperature is when this unit is tripping the breaker? Does it seem to be at a higher outdoor temperature or at all outdoor temperatures day and night?
Did they check the run capacitor to see if it's good and the proper microfarads?
Did they check to see if the breaker trips when it's starting up or after it has been running awhile.
If it's tripping on start up then it's possible the next step is the compressor replacement.
If it's tripping after running awhile then it could be dirty indoor coil or filters,blower not running at full speed,low voltage, loose wire connection, points burnt on contactor and even a weak run capacitor.
Dec 30, 2009 | Heating & Cooling
Electrical short in heater
Hi, Are you saying that the breaker trips after the heater goes off? Normally, if you have a dead short in the system either on the control voltage side or the high voltage supply, the breaker will trip on start up, or shortly after lets say if a motor is over amping and getting ready to die.If this is an open flame heater with a forced air blower, after the space and thermostat are satisfied, the blower will continue to run for a short time to let the heat exchanger cool down before the fan control shuts it off. If this is when the breaker is actually tripping, after the heater shuts off, I would take a look at the breaker its self. It could be that the wire connections at the breaker have heated up over time, and is causing it to trip on you. You can remove the cover to excess the wiring and check to see the condition of the breaker, burned or over heated spots ect. Also, turn it off and take a screw driver to the wire or wires and make sure they are good and tight. If they are aluminum, they can be a real problem as it is out lawed to install in new construction anymore, but I see a lot of it out there, and it will over heat fast if it is loose. If you have this, buy yourself a tube of nolox at Home Depot and put some on the exposed areas of the aluminum. Keeps it from oxidizing. If you have copper conductors, just make sure they are good and tight, and the breaker is in good condition. This may be where you're problem is if it trips after going off. Sounds like it will hold through the heating cycle and is heating up at the same time, as it is drawing amperage, and trips just at shut down. This is unusual but I would start there. Please get back to me on this so I can get this solved for you. Just follow my steps at this point. With the breaker off, there is no power at the screws for you to get shocked, but always use caution. Let me know. Sincerely,
Shastalaker7
Dec 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
Aug 22, 2008 | Whirlpool AD65USL / AD65USM Dehumidifier
Keurig Elite B40 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
