Question about Bosch SHE4AM15UC Dishwasher
My Bosch dishwasher runs for a second then goes straight to clean. I have tried each cycle and it does the same for each. Model number she4am15uc
  • 4 Answers
SOURCE: Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Posted on Oct 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
mark_37388
  • 100 Answers
SOURCE: My Bosch Dishwasher cycle runs for 2 plus hours!
If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
Posted on Mar 28, 2009
  • 457 Answers
SOURCE: My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Posted on Mar 13, 2010
sodeep
  • 3267 Answers
SOURCE: Bosch dishwasher she4am15uc stopped mid-cycle of
check the drain.something is clogging the draining
Posted on Dec 10, 2010
I have a Bosch SHE4AM15UC dishwasher. It's been working fine, but yesterday I noticed that there was water in the bottom of the dishwasher after the cycle was finished.
Check the "P trap" where the drain hose connects under the sink. It may be partially blocked allowing water to syphon back into the machine or preventing it from pumping properly after the second or third pump out.
Nov 19, 2016 | Bosch Dishwashers
Bosch goes straight to clean cycle
I had the same issue, for me this is what solved it.
Clean out the drain filter, remove any water that's still in there using a ladle/sponge/cloths, remove the impeller cover and make sure the impeller is spinning with no resistance. may be some food debris that got stuck or the filter may just be very clogged. Give it a try, it's a simple procedure:
This is from Bosch UK's youtube page:
http://www.youtube.com/watch?v=hfw3vliCf4c
Worth a try!
Sep 11, 2014 | Bosch Dishwashers
How do I fix this problem? When I start the dishwasher, it runs for a minute or two, then stops and the "Clean" light comes on. So far, I have replaced the control panel, the power module, and the Hal
If you pull up on the float and the water burps a couple of times and does nothing else, then your drain pump is bad. It is doing a rinse of the inside before it adds the detergent, if the drain motor is bad it will simply let this small amount of water in the bottom and adjust the indicator to clean. I have had this same issue with mine. One clog and the motor goes kaput.
Jul 27, 2014 | Bosch Dishwashers
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
Mar 28, 2009 | Bosch Dishwashers
Bosch SHE4AM15UC Dishwasher Logo
74 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
