Question about Fujitsu fi-5120C
Reset fi-6130 scan count
Replaced pick roller
4 Suggested Answers
TechSatya
  • 104 Answers
SOURCE: Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Posted on Jul 27, 2010
Testimonial: "Hello TechSatya, The information you have provided is very helpful. We can now notice staple-pins stuck inside the Sensor panel. Thanks a lot."
  • 643 Answers
SOURCE: Hi, I have a
  1. Turn on the scanner, and confirm if it is connected correctly to your computer.
  1. From the [start] menu, select [All Programs]?[Scanner Utility for Microsoft Windows]?[Software Operation Panel].
  2. From the list on the left of the panel, select [Device Setting].
  3. Click the [Clear] button beside the replaced consumable.
  4. Click the [OK] button on the displayed confirmation message.
Posted on Jun 22, 2011
TechSatya
  • 104 Answers
SOURCE: We have replaced the pick roller and the scanner
Hi Tiffany,
This seems you've logged in to your PC as user. The clear option is sometimes not highlighted in user login. You need to login as Administrator to reset the count.
Thanks & regards,
TechSatya
Posted on Aug 28, 2011
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
We are a medical office that is currently using the fujitsu fi-6110. When scanning documents the feeder is pulling through 2-3 pages at a time and we are not getting all of the documents scanned due to...
Hello Jenny,
Please clean the followings using a cloth/ cleaning paper moistened with iso-propyl alcohol:(Pls refer to page-95 of your scanner getting started guide)
1.Pad Assy 2. Ultrasonic sensor 3. Idler roller 4. Pick roller 5. feed roller 6. Eject roller and 7. Glass surface
If the above doesn't help, then check the Pad Assy & Pick Roller count. If the counts exceeds the suggested replacement cycles, then you you may have to replace the same. Pls refer to page-99 of the getting started guide supplied with your scanner.
Thanks & regards,
ScanCare
Sep 12, 2013 | Fujitsu fi Office Equipment & Supplies
Scan multiple pages
Hello Chris,
Please check the followings:
1. Are the multi-feed conditions and paper quality requirements satisfied? - Please confirm whether the documents satisfy the conditions described in "Multi-feed detection condition" and "Document quality" of Error Recovery Guide.
2. Did you fan the document before setting? Has the document just been printed with copier or laser printer? - Please reduce sheets of the document or fan the document 3 to 4 times to remove static electricity.
3. Is the thickness of the bundle of documents less than 5 mm?-Please reduce the number of sheets of the document to satisfy the condition.
4. Is the Brake Roller dirty? - Clean the same
5. Is the Brake Roller set properly? - Please install the Brake Roller correctly.
6. Is the Brake Roller worn out? - Please check Brake Roller and Pick Roller counters, if the recommended cycle has exceeded or if the Brake roller is worn off, then please replace the Brake Roller.
If the above information doesn't help, please contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Thanks & regards,
ScanCare
Aug 21, 2013 | Fujitsu fi-6130 duplex scanner
We have replaced the pick roller and the scanner properties are not allowing us to reset the pick roller count (the clear option is not available as per pages 105 or 112 of the operator's guide).
Hi Tiffany,
Thanks & regards,
TechSatya
Aug 26, 2011 | Fujitsu fi-5120C
Hi, I have a Scanner Fi-6130 and it said to replace pick roller,, of which I replaced both of them. it is still coming up "About time to replace Consumable". I keep ignoring it but am afraid...
Jun 22, 2011 | Fujitsu fi-6130 Flatbed Scanner
My Fujitsu fi-6130 scanner randomly makes a clicking noise while scanning. it seems to working just fine but the clicking noise drives me nuts!. It doesn't happen constantly but it happens enough that I am...
If you have a scanner with the manufacturing date of 3/09 - 8/09, then yes, the clicking noise is more noticeable after it heats up. The problem resides in the glass mounting that was made in production in those months. The glass mounting raises up and if scanning thick paper or cards it will jam up. This must be sent back to fujitsu to replace the base assembly, because this is a defect that affected thousands of customers.
Nov 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Hope the above info is helpful.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu fi-5120C Logo
184 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
