Question about Lexmark Z2420 Printer
Print in Black ink only?
So I am trying to conserve my color ink when printing black and white photos. I was told that there's a way to use only the black ink. Is this true? I have looked everywhere and in every tab I can think of where i might be able to change this setting, and no luck. I know it would change the quality but I'd still like to give it a shot. It would be really nice to have this option considering if I print a big enough photo, my color ink is already gone by like 1/8th and who can afford that? Anyone have any suggestions? Thanks so much!!!
  • Marle_790 Jan 19, 2009
    I've done this as well. And believe it or not, unless I am completely blind, they have every setting, except for that. Even under paper options, they have a box you can check that says "print in black and white" and i have tried this but all it does is a print a picture in "black and white" but you can actually see that it took some from the color cartridge. :(
    Sergeant:
    Champion:
  • 318 Answers
Go to "Start" "Settings" "Printers and Faxes" choose your printer in the menu window,,right click and bring up sub menu,,then choose properties,,you can change all of your printer settings from here.
Posted on Jan 19, 2009
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
I have a pinnacle Pro 901. How do I print in black & white only?
Hello, try this: Start Menu, > Printers and Faxes> then right-click on your printer. Move the pointer down to 'Printing Preferences' and click the 'Advanced' tab. There you will (should!) see 'print in greyscale' . Select this then click 'Apply' then 'OK' at the bottom of the page.
Regards,
nicam49
Dec 01, 2010 | Lexmark X2250 All-In-One InkJet Printer
How do i mix the colours on my stylus sx115 as i have run out of black but have the other 3 colours remaining?
Conserving Black Ink When the Cartridge Is Low (For Windows Only) The window below appears when black ink runs low and there is more color ink than black ink. It appears only when plain papers is selected as the paper type, and Text is selected as the Quality Option.
The window gives you the option to either continue using black ink normally or conserve black ink by using a mixture of color inks to create black. Click the Yes button to use a mixture of color inks to create black. You will see the same window the next time you print a similar job. Click the No button to continue using the remaining black ink for the job you are printing. You will see the same window the next time you print a similar job, and again have the option to conserve black ink. Click Disable this feature to continue using the remaining black ink.
Oct 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision roller.com.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Can't print photo in black and white
Could this be the problem? From the User Guide: "Print Color images in Black and White -- Print your color images in black and white to save the ink in your color ink cartridge.
NOTE: You cannot select this setting if you have selected Color Cartridge for all Black Printing"
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Better way to conserve ink?
Sad but true. This is how printer mfgrs make their money...selling ink.
It's cheaper to take your photos on a memory card or CD to CVS Pharmacy and have them printed
Jan 20, 2009 | Lexmark Z2420 Printer
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
When I want to print using the photo or black ink cartridges, my printer uses the tricolour cartridge. If I take the tri colour cartridge out, the printer alerts that there is a cartridge missing and still...
If what you are trying to print is a black in white image then you cant print that when you dont have the other colors installed. The reason is because your image/photo has shades of gray, and for the printer to produce gray, it needs the other colors as well. It needs colors to get the light black or gray shades of the photo....
If however, you are trying to print text only, the printer should be using the black cartridge and not the other colors... I believe that there should be an option in the printers preferences to select black ink only... look for it under advance tab...
hope this helps
Sep 05, 2008 | HP Office Equipment & Supplies
Lexmark Z2420 Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
