Question about Garden
280915BE Rear Engine Rider Series 15 belt diagram
3 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: Were can I get an Repair and Maintenace Manual for
Go to the following site and enter your model number. The parts manual shows the machine assmbly, and the owner's manual is also available
Posted on Nov 09, 2009
  • 202 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
Got a rear engine rider that the deck belt slips and don't see a tension adjustment
Has your belt stretched and you could try spraying the belt with belt dressing. I did that about once a month till I broke down and replaced the belt. Making sure you get the proper size belt for that machine.
Jul 17, 2014 | Garden
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Diagram to change belts on 25hp 50hp scotts rider mower
sometimes the plate shows a couple size decks that could have came on that model also some mowers have a belt from the engine to the deck then another belt to connect the blades together
Sep 03, 2012 | Garden
Snapper riding lawn mower loosses the power to move up hill from a dead stop even though the motor has plenty of power, how can i fix this? is their a belt that is slipping?
if it is belt driven yes it sounds like its slipping may be worn or some idler pullys are adjustable via a slot in bracket where bolt goes through pully if it is disc driven the rubber disc is probably worn. if mower is a rear engine rider close vent on gas cap,set brake then lift mower from front and stand up on rear bars at bottom by floor you will see a rubber disc which is held on by 4 nuts. if has electric start try not to leave up for too long,should only take 15 min to replace hope this helps
Aug 07, 2010 | Garden
Dec 23, 2009 | Garden
How do you adjust the cutting deck?
Pete, go back to partstree and look at the diagram for lift arms. Item #27 is your lift cables. You will notice there are several little ferrules or balls on the cables, you unhook the cable and slide these up or down as needed to adjust your deck. If you need the deck higher, you would position more of the balls under the lift arm on each side. If you can't get the desired height then your cables are stretched and need to be replaced
Oct 09, 2009 | Garden
I need a serpetine belt diagram
There is a sticker on the radiater support(rad yoke) that gives basic engine info, and the routing of the belt.
Please rate my suggestion..
Apr 11, 2009 | 2004 Saturn L-Series
Garden Logo
29 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
