Child lock is on and tv wont turn on its always on stand by
SOURCE: Sharp 28JW73H
many of the intermitent defec on tv are due to cold solders so check in the power supply area and in the flyback area somes tvs have many cold solders in the large ic that produce intermitent defect...good luck
SOURCE: magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
SOURCE: Child Lock issue
Unfortunately the Child Lock facility disables the buttons on the TV.
You should be able to get a replacement remote control from an authorised Philips dealer, or you could try a universal remote control form most electrical retailers. Philips make a range of universal remote controls.
Instructions for activating and de-activating the child lock are in the manual. If you don't have the manual, download it here:
https://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
SOURCE: Child lock in a Koryo TV 21inch.
Go to the channel where Child Lock is ON
Press " --- " Key ( below channel 9 button) for few seconds,
Child Lock will be OFF
Press again Tune Lock will be OFF.
SOURCE: child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted
trouble--if it gets accidentally turned on and you don't know the code,
you can find yourself unable to fully enjoy the full range of available
television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching
regular TV ....
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
