Question about Fujitsu Computers & Internet
Wireless Network keeps dropping off
Fujitsu LifeBook A531 i5-3210M 4GB Wireless drops off every 10 minutes or so. I have turned off the power-save on the wireless adaptor. The laptop this replaced did not experience the same issue so it's not the router.
SOURCE: wireless router dropping then disappeared
I don't know a solution but the router will appear in the list along with neighboring routers but it will disappear and the others will still be there so it's not an adapter problem something in the router stops sending a signal
Posted on May 22, 2007
smeago1
  • 136 Answers
SOURCE: Wireless Network Dropping Out- NetGear WPN824 V.2 & Atheros AR5006EXS Wireless Network Adapter
Fergus,
Steps to troubleshoot are as follows.
1. check the physical connections. Go to a broadband testing site to see if you are connecting correctly b/c i am assuming you are wanting to connect to the internet. if not see next step. A common problem with internet connections is the timeout setttings on netgear you should set it to 0 for indefinite.
2. if your problem is related to just the connection between your pc and your router then you should just plug a lan cable in first to see if you can connect to the router without dropouts. This will help you to determine if the problem is with the router.
3. If it is the router then you need to double check your router configurations. Common problems are firewall rules, port forwarding settings etc etc.
4. if it is not the router then double check that the pc and the network card is working properly. If it is then make sure the the wireless adapter support the protocl eg. wep, wpa, wpatsk etc..make sure they are the same and that you should be setting the network key.
5. one final check is you need to turn off some of the rangemax functionality on the router b/c your wireless adaptor probably doesnt support it. try unsecure connections for a while to see if it works then start adding functionality to determine which one is the culprit.
I hope this help.
smeags.
Posted on Dec 31, 2007
ceezer
  • 20 Answers
SOURCE: Dell Laptop with XP keeps dropping connection
find the manufacturer/model # of your wireless adapter and download the latest driver from dell's website (you can go to support.dell.com and enter your service tag/laptop model # if you want).
Posted on Jun 10, 2008
Romy_Dec
  • 56 Answers
SOURCE: Wireless working very slow
Hey there
You are not getting this problem due to any BIOS and wireless driver.
as you said that you are not getting any problem with your another system.
Checkout for the range you are working in. else it wont be that much effective.
Sometimes it happens that your driver misplaced or changes its parametetr in registry without awaring you.
So first repair your wireless network
else secondly repair ur XP PRO.
this will surely help you to have a good speed with ur network.
Gimme your acknowledge
Thanx.
Romy
Posted on Aug 09, 2008
Geekman
  • 32281 Answers
SOURCE: Fujitsu P1510 wireless card replacement
Some laptops have a modem or wireless card that clip onto the motherboard like how the RAM is fitted to the motherboard. This card is larger than the RAM and may have one or two wires connected to this card. If so you will be able to replace this card.
If the wireless is a chip and is mounted on the motherboard then it would be impossible to replace.
Your only solution to this problem is to buy a PCMCIA wireless card and insert into the laptop's PCMCIA slot or use a USB wireless device. You may have to go into the BIOS and disable the internal wireless device.
Posted on Nov 26, 2008
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Where is the wireless switch located on the Fujitsu Lifebook A series model AH531?
I'm not sure where the switch is but to enable the wireless connection, you could go to the control panel>network and internet, in the left hand menu choose, Change adapter settings, right click on your wireless network connection and click enable.
Mar 16, 2012 | Fujitsu LifeBook AH531
My c-series fujitsu wireless enabled lifebook is not able to connect to local wireless networks. i checked with the troubleshooter and everything is working, when i try to view available wireless networks,...
Now you just need to access the network gate address at your Fujitsu C2340 LifeBook C Series Notebook ,and open the wireless network function of the router.If you can't access in,it may be request a password,if you din't remenber,ask you friend how did he enter to the page.
May 31, 2010 | Fujitsu LifeBook C2340 Notebook
When I switch my wireless connection sith on at the front of my fujitsu lifebook S7010D the laptop encounters an error and closes down
Use another machine to download latest drivers from the following site: http://support.ts.fujitsu.com/com/support/downloads.html Search for
Device Driver - Intel® PRO/Wireless LAN 2200 BG - LIFEBOOK S7010
or alternatively use the Deskupdate to auto update all drivers for your S7010
Save the zip files to a USB key. Turn the wireless connection off using the switch at the front of your laptop. Unzip and install the new drivers. You should be good to go from here.
Good luck.
Apr 18, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
My router (d-link WBR-1310) keeps dropping internet every 10-15
Try to access the configuration page of your router and look for channel number. Change the channel number to 11 or 13 whichever is available. It should work fine after that. If it still does not work, you can hard reset it by pressing the reset switch on the router. However, then, you will have to configure all the settings again.
Nov 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How can i keep my wireless connection from switching off each time i turn off my laptop. i have to press Fn & F2 at the same time & then refresh through control panel & network connections...
This is not possible. Even if you could keep it powered, it needs to maintain communication through a software/hardware driver.
On another note, it should automatically reconnect upon waking up unless the router is set to drop IP addresses after a very short time. Most routers will keep an IP address leases for 24 hours (1440 minutes). You can change this in the DHCP area of your router.
Jul 30, 2009 | Fujitsu AMILO PC Laptops
No wifi
The Fujitsu Lifebook S5582 does not have an integrated Wireless network card. This laptop was manufactured in 2001-2002. The integrated Wifi card was not generaly common in laptop computers until 2004.
So, you will need to buy a wireless adapter if you want to have wifi connectivity. Since this laptop is quite old, I would recommend a PCMCIA (a.k.a. PC card) adapter instead of a USB because it will be much lighter on the processor load.
You also have to be aware that using a wireless card will use more battery power and therefore shorten the expected autonomy of the laptop when running on battery.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
