Question about Samsung TXN3271HF 32" TV
Only vertical line shown in my tv what s the problem
    Top Expert:
  • Samsung Master
  • 74,468 Answers
Horizontal deflection bypass capacitor open or loose contact. Check it.
Posted on Jan 03, 2013
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
My sony tv 14 inches model. KV-14jrs in when you switch on the picture shown is black with horizontal line. What could it be the problem?
Line left to right in middle of screen is a vertical circuit failure.
A solder connection, a bad chip in that area----14 inch set not likely to be worth the cost of repair.
Apr 16, 2012 | Sony Televison & Video
Horizontal lines are at the top of the screen (First 3-4 inches) rest of the screen looks fine
This seems to be a fault in the vertical blanking circuit. It's very common to have open or out of value electrolytic caps that make this problem.
I could guide you in finding this cap if I had the schematic for this TV, but I don't.
Dec 10, 2010 | Panasonic CT-27SL15 27" TV
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
I recently had my tv repaired for diode problem,it is a samsung LNT4066FX/XAA flat screen.Now instead of clicking sound and not turning on the power bar at bottom stays blue and the picture has color...
Well the capacitor problem usually causes power up problems. If your tv comes on now it sounds like you dont have the same problem.Vertical lines are usually caused by bad flat panel or dirty ribbon cable contacts on flat panel connections.
Aug 19, 2010 | Samsung LNT4066F 40 in. LCD Television
I have coloured vertical lines on my 40-inch Samsung Series 7 LCD tv, sound ok, what is wrong? Can it be fixed, Yasna
is the screen full of vertical lines? It sounds like your Tcon has gone faulty but...there is hope. Firstly, only if you are competent with electrics follow the procedure bleow, else get a qualified tv engineer to inspect your tv.
Remove the back cover on the tv.Looking in from behind, check the power supply which is the board connected to the mains power lead. Check the capacitors, making sure none of them have bulging tops.These are the components shown below.
The caps shown below are an example of faulty caps, with their tops bulging.
This model of tv is prone to this condition, and if you have any bulging topped caps, replace them.
Next check the Tcon LVDS lead connection. The Tcon is the board located top centre of the screen and is enclosed in a metal plate.It has a lead connected to it that goes to the main board. Clean the connector at the Tcon.Be very careful though because the connection is fragile. It can be removed by gently squeezing in either end of the connector and gently pulling outwards.If these procedures are not successful, replace the Tcon.
Mar 07, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
What must I do to get acces to the FIXYA solution for the TEAC CTF 6860 S television solution - vertical line shown on screen when TV switched on, Sound OK?
its not something u can do u need a TV repair guy
i cant walk u .
must be done by TV repairs and some TV are different in the back
Aug 24, 2009 | Televison & Video
I have a vertical line in my rear projection TV - Akai PT4298HD
looks like you have a problem with the crt itself poss a fractured shadowmask the convergance system only changes the magnetic field in the scan coils to realign the cathode guns to keep the scanning in line . coincidental i think, a new crt is favorite hope this helps
Apr 13, 2017 | Akai PT4298HD Rear Projection Television
Red line on screen
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears. 9f78570.jpg
Nov 08, 2007 | LG DU--50PX10C 50 in. Plasma Television
Samsung TXN3271HF 32" TV Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
