Error C03 Hi I have an Appliance365 WM602 washer and it shows error C03, The manual tells me to reposition my clothes but this happens on every load. I believe this may be a balance problem but with what??
fanny
  • 146 Answers
SOURCE: Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Posted on Nov 04, 2007
SOURCE: F21 error code on a Kenmore HE2 front load washer
Unscrew the pump, there is probably objects in the pump, I get that error every month or so, I find coins in my pump all the time, if too much stuff gets in there the code F21 or sometimes SD comes up.
Posted on Aug 20, 2008
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
  • 351 Answers
SOURCE: CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
Posted on May 08, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
Electrolux dish washer error C03
Hello agusta_bjarn - Are you certain the error code is C03? Could it possibly be E03? If so, typically error code E03 indicates that there is a failure with either the wash motor or motor hall sensor. I suggest checking for suds in the tub and siphoning. A further diagnoses is recommended to have a professional check the wiring between motor and main control board since either part could need replacing.
Apr 12, 2013 | Electrolux 24 in. EDW5505EPS Stainless...
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
Jan 02, 2011 | LG WM-1832C Front Load Washer
User manual for a White Westinghouse WM602 washer
http://www.appliance365.co.uk/userfiles/file/MDA/Laundry/WM603%20&%20WM602%20manual.pdf
Nov 13, 2010 | Washing Machines
Whirlpool Calipso model clothes washer shows a LD and doesnt run
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*(@$&
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
MAH 2400 AWW flashing error code "dc"
Hi Pepsi,
"dc" means that the control board is trying to ramp up (that is, send a signal to the motor controller), but has encountered an unbalanced load and so shuts down. Specifically, "dc" means "distribute clothes".
I took this opportunity to upload a Tech and Troubleshooting manual for you. Here is the link for it. Read it carefully. You will be required to perform a "board output" test after placing the machine in "Service Mode".
I gotta tell ya, though. Based on my history with these, I highly suspect that the machine control board has failed. Let me know what you find, OK?
(And don't forget to rate this solution as "FixYA!", deal?
SG
Apr 11, 2009 | Maytag MAH2400A Front Load Washer
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
