Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Sony projection tv middle of screen is faded
There is a large circular faded area on my screen.  The picture still looks good but a portion is faded.  An example would be if the is a close up ona person, he would look really pale if he was in the center of the screen and normal looking if he was on one of the sides.
  • 11,896 Answers
Usually the problem is you have a defective light engine. If it is just a faded circle.
If this spot looked like a certain image, then it would be considered "image burn" and would require the purchase of a image-burn removal dvd program.
If you're certain that it's not your speakers that are causing the problem (easy enough to check by moving them away temporarily) it's worth checking that there are no other magnets or large metal objects nearby, some TVs have an auto-degauss when powered on and off rapidly in succesion or leave unplugged for 20 minutes.
Posted on Jan 19, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try cleaning the face of the tubes. Use can of compressed air or air-blower to clean off the dust. Wipe with a soft cotton cloth.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • 716 Answers
Do A Reset To Determine If Its Hardware Or Settings. Unplug The Tv And Hold On/off For 30 Seconds Then Release And Plug It Back In. On Power Up Try Holding Power/on Off And See If Your Tv Beeps.
Two Different Methods As Tv's Are All Different.
  • Michael Fisher
    Michael Fisher Jan 19, 2009
    Ok I Pulled Up The Manual To Reset. Turn On Your Set, Hold Reset On Your Remote Then While Still Holding Reset On Your Remote Press Tv Power On The Set. The Tv Should Turn Off Then Off Again Now Release Reset.
  • Michael Fisher
    Heres Your Manual By The Way. It Has A lot Of Options For Adjusting Focus And Color That May Fix Your Problem If Reseting Doesn't Work.
    Click Here
  • 818 Answers
See this
1. See the ugly red color bands on the television set? These can also occur in blue and green. We're going to fix these!
sony projection tv middle of screen is faded - 1_sony_convergence_red_lines_bands_projection_tv_problem.jpg
2. Front shot of the television. Their are two screw holes on the front of the unit near the edge of each side right next to the speaker grille.
3. Close up shot of the screw hold. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
4. To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. (see picture) Loosen the cables attached with the twist ties and set the front cover to the left side.
5. With the speaker grille and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
6. This is a picture of the inner electronics of your Sony Rear-Projection High Definition television. The little black box towards the front of the unit is where we will concentrate our time as it is the control for the voltage & convergence adjusony projection tv middle of screen is faded - 6_voltage_projection_red_blue_green.jpgpot.com/_0xPnZbi2QtQ/Rn7bSYP11tI/AAAAAAAACR0/l8UOz9Z4vGw/s1600-h/6_Voltage_Projection_Red_Blue_Green.jpg">6_voltage_projection_red_blue_green.jpg
7. When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment. The colors are labeled below and from left to right are blue, green, and red. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines. In my case, the red just needed to be turned 1/8 of a rotation to be back in adjustment. Do not turn to quickly or abruptly or you could possibly damage sony projection tv middle of screen is faded - 7_red_blue_green_voltage_band_adjustment.jpg
  • 119 Answers
Adjust your convergence
Sony KP-51WS500: This TV comes on for a few seconds of picture and sound. Then the picture fades to green and then turns off within another 10 seconds. Is this a power supply problem? Or should I look in...
Adjust the Green screen drive,turn it down and see if that corrects the problem.
Remove the Front Bottom Panel on front of Tv and behind it will be the Screen/Focus Control block
It will have 3 controls on Top for Focus to each Tube R/G/B
and under them are the Screen drive controls for R/G/B.
But if adjusting the Green Screen Drive Control does not Fiox It ,then you have a Bad Green Tube.
Jul 03, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Have a Sony KP53S65 Rear Projection TV... while watching, it made a pop sound... the picture shrank (faded) to a small circle of color in the middle of the screen and than disappeared to nothing. There...
The tv have blown electronic components Highvlotage deflection circuitries area.This tv is not an easy fix,must hire a tv Tech.get an estamate to troubleshoot and replace components,sorry could be anythings,if it just pop and fade picture away.Well LCD tv is pretty cheap these days,compare prices a new LCD tv or fix up the old DLP tv u determine.The cosmatic appearance,mean nothing in electronics devices.
Dec 30, 2010 | Televison & Video
When the set is turned on, the screen displays a lot of blue dots like an outer space scene except the stars are blue and there is a large circular area in the middle that is yellowish. I still get a...
Hello: Unfortuntely the Optics engine will need to be replaced the blue lcd chip is failing, this will get worse as time goes on. Replacing the optics engine is the only solution to repairing this set back to spec's. Most call them Light Engines..This site will give you cost and example of what one looks like.
Http://www.tristatemodules.com
Nov 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony 51" wide screen rear projection tv
Looks like like you have got some burnt fuses near the D-board. What we are looking for are burnt ceramic fuses. Should cost you around 10$for 8 of them. I advice you replace all 6 and then check if its alright..
Jul 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony WEGA 42" LCD TV
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with Sony and start complaining, then keep complaining until they agree to pay for it. Even if it is out of warranty.
You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Hope ya fix it!
Jan 07, 2008 | Televison & Video
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Picture Fades
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Jul 12, 2006 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
