Question about Belkin F8Z441 TuneBase FM with HandsFree FM Transmitter
Ive got 3 new tune base units .none of the displays light up, but the chargers work.
Kx tg1033c
Have you tried charging (which will reset the handset) in the base charger as opposed to a remote charger? Have you tried moving handset #2 around the house in case the problem is related to interference?
Oct 18, 2013 | Computers & Internet
We have a DECT 122 - 3 hand set and base station. We have difficulty in obtaining a dial tone and unit screen on unit 1 displays the word "SEARCHING" on it. On the base station unit, the...
Hello Haggis,
This problem is with the batteries try removing them and let the phones sit for a little while... once you have done that put bats. back in and place on charger, if your still getting the error message do a reset under the advanced menu. If none of the above soultions work for you please contact me at fixya@whypayforhelp.org and i would be happy to get some more details from you and see if we can figure this out
~Lee
Founder of free tech associates
May 28, 2008 | Lands Phones
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
Bought a replacement battery for extra handset and used the adaptor from the base unit to try to charge the battery. This did not work. Charging notice did not appear in the display window and the charge...
:.. extra handset ..." implies you have another handset. Try the battery from that handset in the "extra." If it works, the replacement battery you bought is defective.
Sep 17, 2017 | Panasonic KX-TG6072B Twin Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
My Roomba will not charge, the light on the charger is on and when you plug in the roomba the light goes out and nothing happens. Can anyone help. It is a Discovery Model 4210
Are you using the home base or are you plugging the charger directly into the Roomba? If you are using the base, give plugging directly into the unit a try.
You might also try resetting the battery. With the battery out of the unit, press and hold the power button for 30 seconds or so. After this is done, plug the charger directly into the unit, and let it charge for 3 days (no kidding, 3 days). After that, if you still have issues, it might be time for a new battery, or time to send the little guy in for repair.
Sep 30, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
    To deregister ALL handsets:
    Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
    Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
    Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
    Step 4: All handsets will show NOT REGISTERED.
    To register a handset (register 1 handset at a time):
    Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
    Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
    After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
    REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
    Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
    IF deregistering does not work .. you will need to reset the entire system
    Step 1: Disconnect the power to the telephone base.
    Step 2: Disconnect the handset battery.
    Step 3: Wait a few minutes and then reconnect the power to the telephone base.
    Step 4: Reconnect the handset battery
    Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
    You will need to set the time and date again after resetting the entire system.
    Mar 11, 2008 | Lands Phones
    Base doesn't recgonize handset
    ya use pensil erser on the connections ok to keep real clean
    Feb 03, 2008 | Uniden TRU9480 Cordless Telephone
    GE Model 27911 DECT 6.0 Additional Cordless Handset not working
    I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
    Jan 20, 2008 | GE 28111EE2 Cordless Phone
    Belkin F8Z441 TuneBase FM with HandsFree FM Transmitter Logo
    24 people viewed this question
    Top Belkin Audio Players & Recorders Experts
    woodzowl307
    Renee Knafel-Bullock
    Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
