Question about Refrigerators
Sears frig condenser fan motor has been substituted from 2199155 to 833697. Original was 10 watt 850 rpm 5 wire, sub is 2 watt 1300 rpm 2 wire. Will this substition work and if so, how to wire in new one
  • 219 Answers
SOURCE: Condenser fan made a lot of noise then stopped.frig warm.
take back metal panel off u will see it then
Posted on Mar 19, 2009
iwillfixforu
  • 619 Answers
SOURCE: Model psc23sgpass GE Profile freezer and frig do
The fan is controlled thru the main control board located on the back of your refrigerator. Pull unit away from the wall and you will see a metal plate. The board is located there and you will need to replace the board. This is a common problem with the GE's. The board is pricey but better than a new refrigerator. If an appliance company told you the fan was bad you should try and get them to refund the fan. wr 55x10942 is the number you need.
Posted on May 28, 2010
Testimonial: "Yep! This was my next step. I replaced the control board and it ran my old evap fan motor. The freezer and refrig are at the proper temp. again. I was able to return the new evap fan motor I bought and tried for full credit."
Sea Breeze
  • 4654 Answers
SOURCE: Have a GE Profile PFS22MIBBB. Just replaced
You will need to unplug the fan and test the voltage coming from the board. You should have 12 to 13 volts DC. Unless you place a fan on condenser that blows air to keep it cool until we locate the problem the compressor can be damaged from over heating. Click here=> GE ARTICA PROFILE TECHNICAL INFORMATION On the first diagram the tech sheet and look for J2 that has both sets of wires for evaporator and condenser fan motors. With new board and new fan you must have a bad connection in the wiring harness. Click on wiring diagram and it will open in a new tab as a Service Manual. Look it over and ask me questions as communication will be very important for you to be able to understand all of this. I will be here when ready so please let me know. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Jun 04, 2010
  • 1218 Answers
SOURCE: Just had the condenser fan
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Posted on Oct 06, 2010
SOURCE: Sub zero 532 - Changed fan motor. Front of the box
alot of subzeros have two comp one for fz one for ff if you do first make sure comp to ff is ok and frean level is ok next check the therm to ff and finnally check that the air flow in the ff is not blocked up
Posted on Feb 20, 2012
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Freezer continues to be warm even though it's full of ice. Vacuum condenser ligth keeps flashing
have you check the condensing unit it could be in need of cleaning depending how old is the unit.also check the fan blades for excessive dirt wich will decrease the rpm o the fan motor.
Oct 23, 2013 | Sub-Zero 632 / S
Sub zero 736 condenser fan not running
You will need to remove the cover around the condenser fan motor then remove the screws holding it down to the base. Remove the wiring from the junction box and away you go. Do not run the unit without a working condenser fan motor, you run the chance of causing yourself many other problems. With a new fan motor the unit should run fine unless there is waxing in the cap tube from overheating. Good luck
Sep 08, 2012 | Sub-Zero Refrigerators
Why does my freg heat up between the doors
2 possible problem. condenser coils super dirty or you condenser fan motor need is out. clean your coils whit a brush, and vaccum (brush 5 doll harware store) cond fan motor is behin the fridge. lower part. the condenser motor run at the same time whit the compressor. if the com run and not the fan. you have bad fan
Apr 01, 2010 | Frigidaire FRS26R4A Side by Side...
I have a 690 subzero refrig that runs almost continually and temps jump around from 38-46..any ideas
I had the vacuum condenser message on my sub zero for about five years. I vacuumed it every six months (as per the owners manual) and the message would go out for about a day and then come back. I figured it was just a bad code.
Recently, my frigerator temp went from the normal 38 to 40 deg F to about 53 to 55 deg F. My freezer temperature was normal (0 deg to -2 deg F). My unit is under warranty (parts only) -- Model 560 -- so I called an authorized service company. They found that my evaporator coil was bad and replaced. I had to pay for labor and freon so my bill was about $300.
Since then -- my warning message is gone and my frig temp is at 38 deg F. Constant. No waivering.
So - for those of you with a Sub Zero with a wandering frig temp and with the "vacuum condenser" message on all the time -- I am suggesting that you get service out to look at it immedately. More than likely -- you have a freon leak and the frig cooling is insufficient leading to the error message ("vacuum condenser"). I am guessing that my frig was running all the time leading to a higher electric bill (potentially -- an extra $10 - $15/month * 12 months * 5 years of owning the house = $600 - $900 of money thrown out the window.
Hope this helps!
Ron
Mar 31, 2010 | Refrigerators
Fan motor replacement. getting the correct replacement motor. I have a model no.,frame no.,,RPM,mfg no etc. but forgot to physically measure the shaft and diameter of the motor. Emerson fan motor model no....
with the model number the supplier shoud be able to tell you what you need but some sell universal variable speed motors with long shafts so trim to fit might come in to play
Nov 20, 2009 | Heating & Cooling
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
My sub-zero frig is running hot on perimeter strip
Usually, this either means that you have a dirty condenser unit or a faulty condenser fan motor. Check behind the top acess panel to the right and see if your condenser is clogged with dust. Also, check that the fan motor up there is going whenever the compressors are running.
Oct 18, 2008 | Sub-Zero 632 / S
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
