Question about Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black
White screen Turned on my pioneer inoo today in the home cradle. the radio recieves and works, but no picture at all. I tried turning it off and on, but nothing. any ideas?
  • 3 Answers
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking it with one hand until the battery came out into my other hand. After about 4 or 5 gentle shakes, it came out. (3) Wait about 10 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Posted on Feb 05, 2009
Tomarmstrong's solution works!! Just take out your battery, and put it back in.. should work fine.
Posted on Feb 22, 2009
The screen doesn't flip when in the cradle. It
I just spoke with Pioneer for this same issue. They said they do not repair the inno2 because it's not cost effective.
Nov 27, 2009 | Pioneer inno2 Portable XM Satellite Radio...
When I set my ipod on the digital media port the screen lights up white and says Digital Media Port okay to disconnect. It worked fine until now.
Had the same problem today. I turned the receiver off, plugged in the ipod, turned the receiver back on. The white screen came back on again. With the ipod plugged into the dock, I reset the Ipod (menu and center button till Apple logo appears). Ipod reset and problem solved. I'm listening to the music now!
Sep 29, 2009 | Sony TDM-IP1 Media Port iPod Cradle...
Screen won't flip when in the cradle
Take it back the store where you bought it at. It sounds like a broken system?
Jan 09, 2009 | Pioneer inno2 Portable XM Satellite Radio...
XM radio express blank screen
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking the battery with one hand until the battery came out into my other hand. After about 4 or 5 gently shakes, it came out. (3) Wait about 15 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Dec 15, 2008 | Pioneer GEX-INNO1 XM Radio Receiver with...
BRAND NEW BUT NO DISPLAY
I also had the white screen / blank screen problem on my Inno today.  I powered the unit off, removed it from the home cradle, and then popped out the battery for about 15 seconds and put it back in.  This fixed the problem.
Sep 13, 2008 | Pioneer XM2go Inno Satellite Radio...
SIR-PNP3
When mine goes time I squeeze the radio downward into the cradle and it lights back up.
Might be a weak connection. I'll have to hit it with contact cleaner sometime to see if it helps.
Aug 06, 2008 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Pioneer Inno Gex-INNO2BK stuck in re-boot cycle
I fixed the reboot cycleing problem by plugging the travel charger into the jack that also fits the home and car cradle. I had the Inno set to auto start when it was powered on in the car cradle. The travel plug must have over-ridden the auto-start setting and allowed it to finish the complete bootup. I then reset the Inno default settings and every thing was back to normal. I do not know what was the original cause of the rebooting cycle problem
Jul 28, 2008 | Pioneer inno2 Portable XM Satellite Radio...
Satellite radio turns on and ond off
I took the reciever out of the cradle and slammed it on the dash a few times and it works fine now.
Jan 15, 2008 | Kenwood Here2Everywhere SIRIUS Radio...
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black Logo
426 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
