Question about Sewing Machines
My Singer Athena 2000 stitch width button has stopped working. I have to press the button many times before the light comes on. Then it works properly. Sometimes when I press the button it will not turn on at all. Any Ideas?
  • J Dearinger Jan 04, 2013
    Could you simply use an electronics cleaner on the stitch width button. Maybe there is a dirty contact internally. But how do you get inside?
  • 69 Answers
SOURCE: Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Posted on Feb 09, 2009
  • 10865 Answers
SOURCE: How do I fill a bobbin on a Singer 2000 Athena
http://www.singerco.com/accessories/manuals.html
go to this site to obtain the manual.
please mark this answer as a fixya!
Posted on Feb 27, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
  • 111 Answers
SOURCE: trouble shooting a Singer Athena
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Posted on Apr 30, 2011
Singer 4423 how to sew a bar tack on denim?
Just set the stitch width selector to the width you want the bar tack and set the stitch length to zero. It will stitch in place until you stop or change the stitch settings.
Oct 24, 2017 | Singer Sewing Machines
Singer 2009 Athena was fine until I pushed some of the buttons to see different stitches. Now there is a red light on instead of amber and it beeps and stops after a few stitches.
look in your manual for a factory reset button or menu, that should take it back to the condition it was bought in an then it should work for you
Oct 02, 2017 | Singer Sewing Machines
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
How do i thread the bobbin on a singer athena 1200 sewing machine
The Athena 1200 and 2000 are "Touch and Sew" slant needle machines. Singer has not made them for many years, but I always loved them, because the bobbin is wound in place--you don't take it out! You can still get a full assortment of presser feet for them; just make sure they're for slant needle machines.
You would be wise to visit the Singer Sewing Machine site and download your user's manual--it's free, and it will show you how to wind the bobbin. There are a series of pictures there as well. There are several steps you need to take, such as raising the presser foot, selecting the blind hem stitch, etc. Sounds complicated, but I owned an Athena 1200, and I can tell you that after the first or second try, you'll find it quite easy.
Incidentally, did you know that it's one of those rare machines that will do a TRUE 1/2" basting stitch! I kept it for years, just for that ability!
Feb 20, 2015 | Singer Sewing Machines
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
Please explain to me how to adjust the numerical, digital buttons on my 7430 Singer sewing machine?
I just took a look at your user's manual, and boy--you're right, and I've been a computer systems engineer for about 30 years!
Actually, it's easier to figure out by DOING rather than looking at the description on page 35. Basically, selection is divided into two categories--utility, that is, stitches you would use for ordinary sewing, like stretch stitches, zigzag stitches, straight stitch, buttonholes, etc. That is located on the left column, with the arrow keys used for navigation in the middle. The display only shows 5 patterns at a time, so to see all of them, you have to keep pressing the down arrow. Once you have selected the stitch itself, you can then select the stitches width and length, and if it's available for that particular stitch, you can mirror (flip) the stitch, and use a twin needle (if it's available for that design)
The decorative and letter stitches are selected on the right column, and work he same way--they are displayed 5 at a time, etc, and selecting stitch width and length, mirror, and twin needle. However, additionally, you can choose to have the pattern sewn once (the default) or continuously.
I hope that helps!
Sep 21, 2014 | Singer 7430 Sewing Machine
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john-michael_38e8d20d2052609c
Mar 23, 2014 | Singer 7258 Sewing Machine
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Apr 27, 2011 | Singer 3116 Simple
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Sewing Machines Logo
64 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
