Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
REPLACE WATER LEVER
HOW DO I REPLACE THE PLASTIC LEVER TO GET WATER OUT FROM THE FRONT.
  • Official Brand Answer
  • 4,342 Answers
Hello Sheri Jarmolowicz - Typically this type of information is not release to someone who is not a technician and it is very rare to locate data on how to repaired parts. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer due to liability reasons. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part (part usually have a 30 day warranty with tech) and whom may guide you through this process.
Posted on Jan 08, 2013
Replace the broken fuel filler flap RELEASE lever on a jag?
Are you going to replace just the lever if so take out the seat bolts and prop up the front . Remove the sill plastic trim and lift up the carpet and there it is. I think this might come as part of the compleat cable assembly.
Oct 22, 2014 | 2003 Jaguar X-Type
How do I dismantle the handle assembley so I can get at the screw under the front? It seems to have some sort of retaining clip at the steaming/water spray buttons
I've just done this 20 minutes ago.
Just between the 0-1-2 lever and the 0-1-2 script is a plastic catch (both sides)
Slide a medium screwdriver into the gap at this point, pushing hard and levering up.
This should just free the catch.
Do the same the other side and then lever the handle up. It will only go up about 1/2 inch.
Now go to the very front of the handle and do the same thing, both sides.
You should now be able to lever the top end of the front piece of handle past the middle piece that you levered up first, and then it will come off, revealing the front screw. Its made a bit more difficult because of the water jet, but comes off with a bit of a wriggle.
When you put this piece back on take care to get the water input spout into the tube before you push down too hard.
(My problem was a main power connector had burned out causing a short circuit and blowing the house circuit breaker. I soldered the connection and it seems to be working OK)
Richard
Sep 28, 2011 | Bosch sensixx TDA 8333 Iron
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Icemaker does not make ice. Appears no water is getting to maker.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 20, 2009 | Refrigerators
Lever that slides from water to ice on frigerator door is broken
You can probably get from from an appliance parts store or heat up some plastic and kind of mold it to the shape of the lever and then while it is hot and soft simply press the plastic over the lever and let it set for about 10 minutes to form a cast if you will.
Dec 27, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Frigidaire Water Dispenser Lever
5304433613 is the part number. It now only comes in black. My daughter's unit was clear plastic, so that is why I am stating the available color..
Jul 19, 2008 | Frigidaire FRS3R5EMB Side by Side...
Fabric Softener does not syphon and water leak from front of dawer.
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 10, 2007 | Tecnik TKL9290 Front Load Washer / Dryer
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
