Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
UNABLE TO ACCESS TRANSCEND JF V30 4GB PEN DRIVE IN WINDOWS VISTA
Hi I have a Transcend 4GB pen drive. M unable to access my pen drive in Windows Vista. Im unable to install Windows Vista SP1 because m using Dial-up Connection and its very slow to install a file of 434.4MB. Is there any alternate solution you can provide to make my pen drive work in Windows Vista.
Regards,
Nirmal
I have transcend JF V30/4GB pen drive. Recently i am getting in the pen drive that i cannot do any format in the pen drive nor i cannot copy/delete the files in the pen drive. it was showing that...
Hello and Welcome to FixYa!
Kindly try this solution:
  • Connect the USB stick to another computer and copy all the data.
  • Download this file (click here) to that PC and format the USB stick using this program.
  • Now try to connect the USB stick to your ACER laptop and see if it works.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Transcend JF V 30 / 256 GB Pen drive not able to format. I want the tool for format the same. I tried with HP formatting tool but unable to complete the format.
GO TO 2003 SERVER MY COMPUTER MANAGE AND DISK MANAGEMENT
RIGHT CLICK ON YOUR PEN DRIVE FORMAT NOW
TO USE HP FORMAT TOOL TO FORMAT YOUR PEN DRIVE
NOTE YOUR WINDO ARE ONLY 2003 SERER AND OTHER SERVER
ENJOY IT
May 17, 2011 | Transcend (589307) Media
THE TRANSCEND JF V30 /64GB PEN DRIVE NOT OPEN, WHEN WE INSERT THE PEN DRIVE WINDOW ASK FOR FORMATING EVERY TIME
I have a transcend flash(pen) drive jf30 64gb.But it does not work properly.windows is unable to format.in the flash drive properties show "File system:Raw".
Nov 16, 2010 | Computers & Internet
Hello friends, i have one Transcend JF v30/2GB Pen Drive. But when i insert Pendrive then i can't access that. It show the error for fromat the drive. Then i go for do that. Then it display error...
This might happen due to an error or corrupted MBR, which is the sector that allow you pen to be readable and the PC might not recognize the system file being used.
I would try to connect it to another PC with a different Operating system and format it from there.
alternative you can also use Transcend recovery tool. You can download from HERE
Sep 24, 2010 | Electronics - Others
My 2GB transcend pen drive is not detected by any computer.this is the first time. pen drive JF V30/ 2GB , Mic-D33193 and SrN. 510747 1741 Please Reply me.
My 4GB transcend pen drive is not detected by my computer.I have use it before 2 times. pen drive JF V30, S/N. 302925-0046 Please Reply me.
Dec 30, 2009 | Transcend T.sonic 612 MP3 Player
Transcend JF v302GB doesn't work on Laptop
try on another usb port. this helps some times. U can check ur pen drive on another system. If it is not working there tehn get the pen drive replaced. If the pen drive is ok, reinstall ur o/s
Aug 12, 2009 | Electronics - Others
Formatting the 8GB Transcend pen drive
check once whether u hv given read only option in properties
Jun 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
Feb 16, 2008 | Transcend T.sonic 612 MP3 Player
Electronics - Others Logo
612 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
