Door Bosch WCM41 - Washing Machines
2 Suggested Answers
  • 6277 Answers
SOURCE: drain plug on bosch wcm41
It's probably not seating properly. Remove it and the filter and pour/squirt anticalc in, around and at the back of the filter AND thread area and clean it out. You will be able to tell whether it's cured as you screw the filter cover back on.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 22, 2011
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
What does E1 error mean
The Bosch E1 error code indicates the door is not completely closed. This maybe due to something holding the door open, such as clothes trapped in the door, or the latch may not be holding the door securely.
Feb 18, 2015 | Bosch Washing Machines
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
A fault code EZ is showing up on a Bosch WCM41 and it doesn't finish a cycle proprley. What does this mean and how do I fix it? Many thanks, Maggie
Hi Maggie from retired Englishman in SW France,
I think you will find that is 'E2' but I do not have your washer type in my Bosch list ;-0(
No promises but it's worth carrying out the following ANYWAY and it might just help ;-0)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Jul 14, 2011 | Washing Machines
Drain plug on bosch wcm41 leaks now after removing to drain drum. Cheers David
John C
Jun 22, 2011 | Washing Machines
Door latch is broken. Door wont close. Is it possible to buy replacement door?
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Jan 10, 2011 | Bosch Axxis WTL 5400 Dryer
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch washer
This video will show you how to change a door seal on this bosch
Jul 06, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
