Question about MSI K8MM-V Motherboard
Is there a 1394 connection - MSI K8MM-V Motherboard
  • MSI Master
  • 5,660 Answers
MSI Support > K8MM-V mobo > Main Support page,
(MOtherBOard)
http://www.msi.com/product/mb/K8MM-V.html
Click on the (Bad) photo of the motherboard.
Also, for the Motherboard Manual;
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc)
In the drop down list click on -> Manual
Under the subheading -> Download, click on the blue ->
M7142v1.0.zip
Click on the blue -> Download 1
A small window will come up -
Opening M7142v1.0.zip
Make SURE there is a Green dot in the small circle, to the left of - Save File.
If not; left-click in the empty circle to the left of - Save File.
Now go below in the small window, and click on - OK.
A small download window will come up.
Allow the file to download all the way, then DOUBLE-click right on the file name.
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last window DOUBLE-click right on the file name. (It is next to the red Adobe PDF icon)
There is your motherboard manual.
The answer is NO.
There is NO Firewire 1394a header on the motherboard.
If you desire Firewire (1394a), and have an open white PCI slot, then suggest using a PCI Firewire adapter card,
(Full name. Short? PCI Firewire card)
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1734001&CatId=510
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 02, 2013
I cannot install my wireless printer as its says Unibrain 1394 does not have a driver
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark you will need to update or install the driver
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
if you dont have the driver you will need to download one
http://download.cnet.com/unibrain-1394-firenet-adapter/3000-2112_4-73440.html
http://download.cnet.com/unibrain-1394-firenet-adapter/3000-2112_4-84320.html
hope it helps
May 26, 2012 | Unibrain, Inc. Unibrain 1394 FireNet...
Good Day! How will i connect and manage my camera to computer.
For the DCR PC101E you need to use a firewire cable or 1394 cable or the i-Link cable which goes to your computer this is one and the same thing with different names. However if your computer does not have a connection for this you must go and buy a 1394 pci card that you have to connect inside your computer. These usually come with the software drivers for the 1394 card.
Mar 16, 2011 | Sony Handycam DCR-PC101E Mini DV Digital...
What dose the icons mean on front panel what is the little square hole for next to the mike connection
hello, it is most likely a firewire connection.
FireWire, originally created by Apple and later standardized as IEEE-1394, actually preceded USB and had similar goals. The difference is that IEEE-1394 was originally intended for devices working with lots more data -- things like camcorders, DVD players and digital audio equipment. IEEE-1394 and USB share a number of characteristics and differ in some important ways. Here's a summary:
  • Like USB, IEEE-1394 is a serial bus that uses twisted-pair wiring to move data around.
  • However, while USB is limited to 12 megabits per second, IEEE-1394 currently handles up to 400 megabits per second.
  • USB can handle 127 devices per bus, while IEEE-1394 handles 63.
  • Both USB and IEEE-1394 support the concept of a isochronous device -- a device that needs a certain amount of bandwidth for streaming data. This mode is perfect for streaming audio and video data.
  • Both USB and IEEE-1394 allow you to plug and unplug devices at any time.
hope this helps,
regards
Amar Sondhi
Dec 05, 2009 | Medion M3 Director 5100 PC Desktop
How to connect panasonic nv-gs150 with dv to pc in 1394 port ?
You need to purchase a IEEE/1394 firewire. They run around $40-$55 for a 5 foot wire. The 1394 end goes into the computer and the other end goes to your AV/out port on the cam.
Oct 09, 2009 | Panasonic NV-GS150 Mini DV Digital...
How to connect IEEE 1394 (4 pin) to computer
IEEE 1394 is commonly referred to as Firewire. Your Dell doesn't support it. You will have to purchase a firewire adapter card and install it and its drivers into your computer.
Apr 22, 2009 | Dell Dimension 2400 PC Desktop
I can't get pictures off of my camera and onto my computer. When I plug in the firewire, the camera is not visible on the desktop.
What operating system are you using?? Windows or MAC?
For Windows, make sure the 1394 Connection is Enabled.
Go to Control Panel > Network Connections > 1394 Connection right-click then Enable.
OR
Right-click My Computer > Properties > Hardware > Device Manager > Network Adapters > 1394 Connection right-click to Enable
May 05, 2008 | Cameras
1394 will not let me online
do you need a LAN driver?
Nov 18, 2007 | Intel Motherboard
Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
MSI K8MM-V Motherboard Logo
134 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
