Question about Acer Iconia Tab A200 Series Tablet with 16GB Memory - Metallic Red A200-10R16U
Tablet won't charge
  • Anonymous Mar 13, 2014
    Tablet won't charge. Have tried other adapters and none work.
  • Anonymous Mar 27, 2014
    my rca 9inch tablet stopped charging.
    Genius:
  • 1,669 Answers
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Posted on Jan 02, 2013
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
May 24, 2013 | Samsung Tablets & eReaders
Mid model m729b
I have similar problem, my buttons on the right side including yjr start button have slipped inside the case and I can not restart the charged device, Can you help?
Pat Green, pgrex@hotmail.com, 409-782-2572, thanks if you can help.
May 07, 2013 | mid Archos M729B Android Tablet
Won't turn on
try holding the power button down for 8- 10 seconds... then release. Still not on? Is the unit charged?
Jan 20, 2013 | Sharper Image Literati Reader 16375680042...
Battery won't charge
Hello,I had the same problem with my new tablet and I sent it back to Coby and still have not got my new one.The company is sorry as far as I'm concerned. I tracked my tablet and it got to them on Dec. 7th and I still have not got my tablet,no replies from emails,nothing from Coby!!!
Jan 15, 2013 | Coby Kyros 716829701508 Tablet PC
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Acer Iconia Tab A200 Series Tablet with 16GB Memory - Metallic Red A200-10R16U Logo
575 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
