Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Dryer buzzer does not shut off. Dryer drum does not turn.
Model # WSM2400LDBWH GE Washer Dryer Combo (1993)
Dryer buzzer does not shut off when dryer is in any of the"off" positions on the dial (unless door is kept open). Buzzer does however shut off when dial is not in an "off" position but is instead in one of the "dry" cycle positions while door is closed.
Dryer does not work (dryer drum does not turn at all) when "start" button is pushed (while in any of the "dry" cycles). But I can hear a "hum" and the hum remains unless I open the door and keep it open. It hums regardless of whether I push the "start" button or not so I must keep the door open in order to stop the humming.
Do I need a new start switch or is something else wrong? Thanks!
  • 1462 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Posted on Mar 28, 2007
  • 3 Answers
SOURCE: dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Posted on Feb 18, 2009
SOURCE: kenmore 700 series washer motor humming noise
ffsdaffdsa
Posted on Mar 30, 2009
  • 240 Answers
SOURCE: GE model WHDVH626FWW Front load washer won't run, can't open door
your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
Posted on Apr 26, 2009
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
Mar 23, 2015 | Koolatron 1.7cuft Thermoelectric Fridge
Turn off buzzer on frigidaire dryer LGR331SO
Good Afternoon Friend,
I understand that you want to turn the buzzer off of your Frigidaire dryer, model# LGR331SO. With your model dryer, you are not able to turn the buzzer off. I hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer will not turn on
if u have recently replaced the belt, the drum may have come out of the track. i suggest taking it apart and making sure the drum is seated correctly. i had to do this several times to my mothers ge electric dryer.
Nov 15, 2011 | Frigidaire FGX831CS Top Load Stacked...
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
How to turn off dryer buzzer
Click on the URL below for a solution to the annoying buzzer that you have:
http://www.fixya.com/support/t2853760-ge_spacesaver_dryer_buzzer
If this helps, be sure to give the 'thumbs up' to the person that wrote it (JanAugCPA)
Good luck.
Mar 01, 2011 | GE Spacemaker Washer and Dryer Electric...
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
I would like to know how many belts a kelvinator dryer has made 8/1991, and the model number is DET 400-G2D. Serial number: XD13423136. the end cycle buzzer will not shut off once the cycle comes to an...
Hello dmjohn39,
Welcome,
I am Huuum at your service!
You said,
You would like to know how many belts a Kelvinator dryer has made 8/1991, and the model number is DET 400-G2D. Serial number: XD13423136.
The end cycle buzzer will not shut off once the cycle comes to an end
It appears to take only this one belt according to the book!
You can find the belt at one of our many our Sponsors, site below!
I have typed the belt # and cost for it at the site.
I am sure they will have the buzzer too!
Item # Price
3372 $14.10 + 4.00 shipping I believe
Dryer belt length 87 3/4”, width 1/2”, characteristics, flat
Recommended related item(s):
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Thank You for using fixya.
I was happy to solve your questions!
Please remember to leave a rating!
Oct 13, 2008 | Frigidaire CWS3600AS Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
154 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
