I have a bose cinemate system. the house i just moved in to has prewired in the walls, speaker wires. Is there a way I can use the existing 2 wire that is in the wall to connect to the back of the speakers that preently have a 4 pin plug
5 Suggested Answers
renx
  • 71 Answers
SOURCE: Wiring into walls
Okay, here's the verdict. No such din connector for the Bose AM15's exist. I thought I would take another look to see if anything had changed since I had looked last. Once again, all is the same and it makes using standard wiring a pain. However, it is possible to do what you want to do, which I assume is a nice clean install. I have rigged many of these systems, and, here's what I do.
First, the biggest pain is the 25' LFE cable. Shortening it is a pain because the wires are thin and dificult to splice. Lengthening it isn't a great idea either because you want to keep the cables as short as possible. However, a lesser of 2 evils exist and that is to keep this cable whole. Before you begin, peel the LFE cable from the buch untill it is separated from the bundle. Next, peel the speaker wire for each speaker so the pos and neg for each speaker is together, but, separated from the bundle. Then you'll place the sub where you intend it to go, plug in the 13 pin din (I even looked at vga options...nada) and stretch the cable to the wall and cut one speaker wire at a time (+ and -) being CAREFULL to mark which wire is positive and which is negative after the cut. DO NOT cut the LFE cable, and make sure you give yourself an extra foot or so before you cut the wires.
Once the cuts are complete and you have labeled pos and neg for each wire, you may strip the wire and plug into your regular speaker wire wall plate (banana or clips). On the reverse side of the plate, attatch the pos and neg to the plates making sure everything is consistant. Then, run the wires to your receiver (or vise versa). Regular speaker wires typically distingush pos from neg through some sort of marking on the wire housing.
The other cable you will run is the sub (LFE cable). If you want to just drill a hole in the wall and stuff the cable in and run it to the receiver, that's one way, but if you want to keep it clean, use a single RCA connection wall plate. Then, to minimize loss of LFE sound, run a TV coaxial cable from the sub to the receiver and terminate both ends with RCA terminators.
Once the wires are run to the receiver, double check that all the speakers are hooked into the sub and the wiring is complete. Take a AA battery and mark the location of the speaker that corresponds to the wire. In other words, with the speaker wire, hold one end to one side of the battery and the other end tap lightly to the other side of the battery. You will hear a crackle or pop locating the speaker the wire goes to. Once this is identified, label the wire and plug into the appropriate output making sure the pos and neg are consistant.
A picture is worth a thousand words, so, I drew a diagram and will attach it to this forum asap. Good luck and have a blast!
Posted on May 06, 2009
SOURCE: connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Posted on Oct 06, 2009
  • 11800 Answers
SOURCE: I need the wiring diagram
There are just 4 wires connecting in that jack: 2 grounds and 2 hot. You can identify them yourself directly either just by looking at the rear pins (where and how they are soldered on the board) after you remove the back cover, or by testing them with an ohmmeter (to the metal side of the jack): the 2 ground wires will show 0, the empty ones will show infinite and the hot ones will show 0 in the moment when you connect it then the resistance will grow fast toward infinite (if after that you reverse the polarity of the test wires you will get initially a negative resistance).
Posted on Dec 28, 2010
SOURCE: splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Posted on Nov 27, 2011
Splice Bose speaker to connect to receiver
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
I need to move my subwoofer another 3 feet and don't have enough speaker cable that ends with the serial port. The cable runs from a fireplace mantle and through the wall. I thought I had enough cable, but...
Unless Bose offers a longer cable, which it doesn't sound like or they would suggest you buy one from them, your options are limited to splicing. Just make sure your connections are good and protected with electrical tape not duct tape or scotch tape. You can even use small wire nuts and electrical tape.
May 22, 2010 | Bose Cinemate Digital Home Theater System...
Video went out/black screen
you possibly have a bad video wire. try a new pair and see if it still does it. if probly still exists you may have a short in the bose or even you signal source
Jul 18, 2009 | Bose Cinemate Digital Home Theater System...
Bose cinemate will not power on. light stays red?
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
Jan 25, 2009 | Bose Cinemate Digital Home Theater System...
Bose cine mate speakers
No it won't be like surround sound, but you'll have the next best thing: a nice, powerful, natural Hi-Fi sound. I have a 46 inch 1080p Sony connected to a Sony Blu-Ray and Bose Cinemate Speakers. No complicated rear speakers wiring, no awkward center speaker to hide. The only drawback is that Bose doesn't have (yet) a code to operate the Blu-ray player with the Cinemate remote control.
Hope this helps to make your decision.
Feb 17, 2008 | Bose Cinemate Digital Home Theater System...
No Sound
Id call you local stereo shop. I changed the head unit out in my old acura legend and had the same problem. You need to buy a special harness for the bose. Each speaker had its own amp, so i just rip it off and wired the speaker direct and trashed the amps. Now this was an older car and speakers were almost shot so no biggie. I would not recommend you doing that on and 04. Just call your local stereo shop and they should hook you up.
Feb 13, 2008 | Kenwood DNX7100 Car Video Player
55 people viewed this question
 Grubhead
Grubhead
