Question about GE (PSS26MSRSS) Side by Side Refrigerator
My ge refrigerator is collecting ice behind and under the evaporator fan behind the ice maker. My first clue is the loud noise of the fan chipping away at the ice. I defrosted the ice enough for the
The ice make seems to work fine as it will still slowly make ice and drop but it does not have much time before the fan starts to chip away at the ice build up.
  • Dan Webster
    Dan Webster Jan 02, 2013
    https://sites.google.com/site/sublimeapp...
  • Dan Webster
    All siagnostics can be performed from the board as seen on the video I have a service manual. Let me know if the link works
  • GE Master
  • 8,220 Answers
Defrost issue:
https://www.youtube.com/watch?feature=player_embedded&v=BrSQz-5F1hs
Posted on Jan 02, 2013
  • 35 Answers
SOURCE: GE profile side by side refrigerator
Replace Evaporator motor .
Posted on Dec 09, 2007
  • 12 Answers
SOURCE: GE Bottom refrigerator/MOdel GS18LCRABB
I can only wonder if the drain tube has been cleaned out to make sure water flows into the pan .Also make sure it is fully defrosted and left over water will freeze quick.
Eeggman
Posted on Mar 10, 2008
  • 148 Answers
SOURCE: GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Posted on Jul 07, 2008
  • 1462 Answers
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
  • 152 Answers
SOURCE: GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Posted on Feb 28, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Our GE side by side makes a terrible humming noise. We've cleaned out the ice maker and cleaned out behind & under the fridge.
the fan in the freezer porbebly tuching something (ice..) or the fan next to the compressor tuch something ... check it out ...
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GSH25JFRFWW evaporator fan makes loud deep noise at times
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Nov 15, 2009 | GE Refrigerators
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ratteling noise behind the ice maker on GE PSS26MSTESS
Sounds like a bearing is going in the evaporator fan motor. Remove it and check for excessive side play in the fan motor.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Nov 18, 2008 | Refrigerators
Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
103 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
