Question about Music
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I had the amp working for a rehearsal, then later in the day I took it to the gig and when I turned it on, checking both channels and all knobs down, the amp made a very loud buzzing sound. The Guitar signal stil goes through, but it's hard to hear over the buzz. I checked out that pre-amp test, and the guitar signal indeed came out of the headphone jack with the speaker unplugged. Also, when the speaker is plugged in, signal still comes out of the headphone jack, but the loud buzz and guitar signal come out of the amp speaker. The only thing I did between the rehearsal and the gig was unplug the speaker cable so that when I started up the amp it wouldn't make that horrible squeeling sound. When I plugged the speaker back in, the buzz started. Ideas?
    Top Expert:
  • 24,742 Answers
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Posted on Mar 20, 2017
2 Suggested Answers
  • 31 Answers
SOURCE: Marshall MG50 DFX amp line out/headphones not working
Well, your problem isn't very descriptive to help troubleshoot online, but first question would be; are you using the correct size jack? The second would be have they worked before? If the answer is yes to both questions, then the problem might be the jack itself on your amp. There is a prong inside the headphone line that hugs the plug to your phones. If the prong has loosened enough where the connection is poor or not at all, you will not get any sound. If the headphone jack has NEVER worked before, than it sound like a wiring issue on your board somewhere. If you are not familiar with a soldering gun, then I would take your amp in to get it fixed. should be a minor quick fix costing anywhere between $15-$30 to have a shop do it. Hope this helps. (also try different headphones if you haven't already. Could be a bad pair)
Posted on Mar 09, 2010
What do i hook plug from marshall dfx foot pedal to amp and guitar
If you're asking if the foot pedal goes between the guitar and the amp or straight in to the amp then it's the latter.
Dec 14, 2013 | Marshall Amplification Music
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
When turning my Marshal MG250 DFX on, there is a terrible buzzing sound. I have tried it on different speakers and the buzzing still occurs. It does not change in volume when i adjust the volume. Whats the...
This is likely a filter capacitor issue. The right tool to troubleshoot is an oscilloscope. This could also be a failed power amp that is driving high DC current with ripple into your speaker. This can permanently damage the speaker. Repair this before using it.
Jan 13, 2011 | Marshall Amplification Marshall MG250DFX...
My marshall mg50 dfx keeps cutting out and stuttering, any idea what the problem is? It sort of cackles as well when the volumes increased giving me different variations in sound.
As a guitar player myself learn that not all speaker from some amps hold the ouput wattage. The fuse could ba a problem or the speaker is giving out.
Jun 29, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall MG50 DFX makes a squealing noise on power up
Yep, chalk that one up to poor design...The amplifiers are going out of balance during power up and down. Two seconds is pretty long... Try turning down the gain during power on and see if that affects it.
The pop on turning off is normal... None of these have speaker disconnecting hardware that is necessary for very high power amps. The biggies have hardware that checks amplifier is balanced before connecting the speakers and a relay also cuts the speakers immediatley on power down. As power goes up and down the circuitry comes to equilibrium and until it does, strange things happen.
I would investigate the CONDITION of the filter caps for the main power because if they age to a higher internal resistance that COULD cause the high freq oscillation on power up... Two seconds is MUCH too long.
There should also be some non-electrolytic caps NEAR the power output transistors to handle high frequency supply power bypassing.
Check the power bypasses that service the preamp stages. Look for pregnant electrolytic caps that have failed.
Ultimately, you MAY need an oscilloscope to isolate the high freq problem.
Jan 03, 2010 | Marshall Music
JCM2000 DSL100 No Sound
Not likely to be a fuse. The bane of electrical amps are the connectors.
Often the speaker and more commonly the input 1/4 inch connectors go bad. Sometimes caused by side loads when cables are yanked or tripped over.
Be careful of running amps IF the speakers are not connected OR have bad connectors or cables. You can arc over the tubes or pop transistors.
Get a cheap Volt-ohmeter from HarborFreight or Radio Shack and test your cables and connectors.
For a tube amp, your should find relatively low resistance at the speaker connector (certainly under 20 ohms). Do this with power off.
Sep 09, 2009 | Marshall Music
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
98 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
