Question about Whirlpool Refrigerators
Constant, slow leak from water dispenser on whirlpool refrigerator
How do you fix a slow leak in the water dispenser of a Whirlpool ed25rq side by side? the unit won't dispense water when the lever is pressed (this problem began several months ago), but the slow leak just started yesterday and continues whether or not the lever is pressed
You might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Posted on Jan 02, 2013
5 Suggested Answers
  • 38 Answers
SOURCE: Water Dispenser on Side by Side not dispensing
It's quite possible it is plugged by hard water deposits forming in the supply line as these lines are quite small. You can check if it is plugged by shutting off the supply line and removing it. After removal turn it back on but have the end in a bucket in case the blockage is in your fridge unit. If water comes out it is in the fridge. Usually there is a screen to prevent large particles from entering. Make sure that is clean. Try these and see if that helps. If it doesn't get back to me as the trouble shooting will get more intense. I'm hoping this helps.
Posted on Sep 11, 2008
SOURCE: Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Posted on Dec 31, 2008
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool refrigerator water dispenser won't stop
Hi. This will usually be the fault of the water inlet valve. The solenoid based valve may have debris building up, thus, causing the valve not to close properly, after usage. Kindly, follow the procedure below to confirm the damage, replace the valve, if needed.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Nov 25, 2009
Whirlpool side by side refrigerator leaking water, model # GS6SHEXNSOO. How do I fix it?
more info needed were water is leaking from door of freezer or fresh food or from bottom of ref. may have cracked filter housing or water dispenser line tell us more
Nov 04, 2016 | Whirlpool Refrigerators
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water supply line to the ice maker on my Whirlpool side by side refrigerator is visibly frozen, and will not supply water to the ice maker. How do I fix this?
With the information given , I would say to pull fridge out from wall , and remove the 2 screws holding the spout . Pull the spout out and defrost with warm water . Reinstall the spout and replace the water inlet valve . Valve had to have a slow leak for the tube to freeze . A model number would have helped to give a more precise answer .
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My whirlpool refrigerator water works fine but it wont make ice anymore what can i do? model # ed2fhaxst05 or o5
It would suggest a possible refrigerant charge problem, it has a constant load unless water pipework impaired i some way? so i would have the charge checked to see if its leaked slightly.
Jun 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
154 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
