Question about RCA Audio Players & Recorders
Rca352w when on it pops then freeze
  • 3 Answers
One of your on-board chips turns-on a protection.Check all cables & whether they are switched correctly.
Posted on Jan 02, 2013
What does a freeze plug look like
A freeze plug is a smooth sided (not threaded) "plug" or "cup" that is pressed into the side of a cast hole in the engine block, leading to the water (coolant) jacket. Its purpose is to be able to pop-out should the coolant in the block ever freeze (such as when antifreeze solution is too diluted or running straight water as coolant). Since water expands when freezing the freeze plugs will pop out, relieving the pressure, rather than having the block crack. Here's some pics of freeze plugs.
Sometimes older freeze plugs corrode, since they are made of metal only about 1/16" thick, and start to leak. That's the most common reason they are replaced.
The link below is a better pic of a freeze plug in the block.
http://www.my2002tii.com/april2004/pic-%20116.jpg
Oct 29, 2014 | Cars & Trucks
Rear freeze plug
i have done a many of these on your type of car its a lil more difficult. you will have to locate it and get to it the best you can take a sharp object,preferably a small chizzle and pop a hole in it once you have a hole you can slowly start to pry down ward to try and pop it out once you have it out they offer a universal freeze plug at the autozone's i recommend the universal it'll be alot easier to put in....good luck
Apr 16, 2014 | 1991 Lexus LS 400
Replace freeze plug
Chances are the block does have freeze plugs, but they would have nothing to do with the engine not cranking. The plugs are a thin metal cup that will pop out if the block freezes to help prevent the block from cracking. Even if they pop out the block can still be damaged. That includes the cylinders.
If the plugs popped out, you would loose what was in the radiator.
Mar 12, 2014 | Chrysler Pacifica Cars & Trucks
1999 buick freeze out plug
Sounds like you have a leaking freeze plug, you will need to replace it, hopefully it is rusted and leaking and did not pop out due to freezing temp, some of these plugs are in spots thatcan cost alot to replace, the plug itself is a few dollars and new coolant . the cooling system needs to be drained because when plug is removed all coolant will run out , the plugs are all over the block, this is designed to pop out plugs and not crack block if there is not enough coolant and to much water and it freeze in cold weather the water expanding pops plugs and not cracking block, some are behind ****** or bracket and so on, you will need to locate the leaking one and see if it is something you want to do. good day
Sep 03, 2012 | 1999 Buick Century
Will the freezeplug make the car run real funny if it pops out
If your Freeze plug pops out the coolant will leak out. The car will overheat and eventually (with in minites) run bad and then it will not run at all. The question is what caused the freeze plug to pop. If the coolant froze inside the engine you may have bigger issues than the freeze plug, There is a strong possibility that you have a crack in the block or heads or in the head gasket. This would affect the engine performance.
Apr 05, 2011 | 2000 Dodge Neon
Why do the freeze plug keeps popping out and keeps over heating change t stat and water pump
If your in sub bellow zero weather you need to install engine anti freeze not water this is the cause of freeze plugs popping water in your cooling system if you install anti freeze this should stop these from popping out on =you.
Jan 09, 2011 | 2001 Volkswagen Beetle
It will not pull up when i try to login. the feeze keep popping u
What is the best thing to do when your screen freezes up?
Aug 04, 2009 | Facebook Social Network
Hood release won't pop hood
you have to let that hood release get warm enough so that it will pop open then put some motor oil on the mechanisim so it don't freeze up again.. good-luck ray
Jan 16, 2009 | 1999 Pontiac Grand Prix
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
