Question about Kitchen Ranges
I simply need a manual for my range. I have a service man coming. Is there one online?
THE BAKING UNIT BLEW. AFTER REPAIRING A BURNT WIRE ON THE BACK OF THE OVEN EVERYTHING SEEMED OKAY AGAIN. HOWEVER, THE THERMOSTAT DOES NOT CONTROL THE TEMPERATURE. BISCUITS BURN IN FIVE MINUTES. TRIED THE PROCESS OF MINUS 25 DEGREES. NO DIFFERENCE. DOES THIS MEAN THE MOTHER BOARD MUST BE REPLACED?
  • Kitchen Ranges Master
  • 8,220 Answers
Check your oven sensor. If it is open or shorted to frame it is bad. It should read 1100 ohms at room temp.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 02, 2013
SOURCE: Hotpoint RGB745 Gas Kitchen Range
I eventually replaced the oven ignitor. That has solved the problem.
Posted on Aug 29, 2007
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
aborcass
  • 2651 Answers
SOURCE: What does E2 - F3 - code mean on a Whirlpool Accubake Gold??
F3 - E2 Oven too hot Replace oven temperature sensor
Posted on Jan 11, 2009
Turned the oven on and heard something pop behind the stove and realized neither of the two oven elements would come on. The top 4 burners all work. It is a Frigidaire- Self Cleaning Mod.-...
there is a chance that one of the wires has burnt to the baking element. you will need to pull the unit out unplug it and remove the back panel. and check the wiring if it is burnt you can replace the burnt part so long as there is not to much destroyed you may have to add a piece of new wire.
you can use regular but connectors and spade connectors to replace the bad parts.
Mar 03, 2011 | Frigidaire Kitchen Ranges
Had foolishly tried to remove baking element w/ oven turned off but still plugged in / breakers still on (all to make cleaning easier-ha!) unscrewed element beleiving it was modular like stovetop elements....
Some times s**t happens. The most likely situation is the wire connections that connect the heater have burnt off, or simply just become disconnected.
the normal repair or replacement to the lower heater element would be to disconnect the wires from the heating element by sliding the wire off of the spade connector. Some times they are connected by a screw and nut terminal. Next to remove the screws from inside the oven, and then pull the element out from the back wall. I can see how you could easily interpret that they would slide out like many stove top elements.
In your situation confirm that power is off.
Remove back panel and check terminal' connections to the heating element. repair.
Model ra520w3 HOTPOINT ELECTRIC RANGE Parts
maxresdefault-es3dyrcoa4nhevk3e5ork442-3-5.jpg Hope this helps?
Jun 21, 2017 | Hotpoint RA520 Electric Kitchen Range
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
Jenn-Air SVE47100 Oven Won't Heat
are you still getting power to the oven? breaker ok? there may also be a fusible link somewhere on the circuit
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
BAKE IS NOT WORKING
It sounds like you have a bad bake element. If the bottom element isn't glowing it may be bad or have a wire burnt off at the terminal end. You would heva to remove the element and have ytour local appliance parts store test it for you.
Apr 06, 2009 | Frigidaire FEF366 Electric Kitchen Range
Oven doesn't work after replacing the bottom (baking) element
Will the clock control accept the bake and temperature request?
If so,
You will need to remove the rear panel of the range and test the bake element leads for 220 volts when the oven control is set to bake and is turned on.
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
